I have the following error in a bridge of my model when I run an unsteady flow simulation.
The error is the following:
–PROGRAM ABORTED–
NEGATIVE AREA IN SUBROUTINE CONVEY
BETWEEN STATION   1813.04 AND    2035.76
Paglia Reach 1 -12172.7
THIS IS USUALLY CAUSED BY BAD STATION/ELEVATION DATA
IF THIS NODE HAS A WEIR (BRIDGE etc.) CHECK THE ROAD DECK DATA CAREFULLY
Someone knows how can be corrected these error?
I checked the elevation/station data of the bridge, and increase the value of the htab of the bridge, but the problem does not dissapear. I also checked the hydraulic properties table, the htab curves of the bridges and looks well as well.
Thank you,
Sara
