Welcome to the RAS Solution Forums HEC-RAS Help need your help how to resolve this issue
  • This topic has 3 replies, 1,881 voices, and was last updated 9 years ago by Anonymous.
  • #6390
    HEC-RAS Error – Incomplete data, the following errors were found:
    SA/2D Connection: outFlowFarash
    Computed weir stationing on the Headwater side is not increasing, check the structure data (weir stationing and centerline)
    and 2d mesh in this area to fix this problem.
    Computed weir stationing on the Tailwater side is not increasing, check the structure data (weir stationing and centerline)
    – A weir line has not been entered for this storage area connection. If there is to be no weir flow, enter a weir line with an
    elevation above expected stages.
    #10466
    To solve this problem, edit your connection, then set the stations and elevations of your weir.
    #10467
    I get a similar error, but have a connection. It was helped by moving the tailwater flow area closer to the connection in my last model, but in my current, no dice.
    #10468
    Lonnie A
    You can often figure out where the problem is by looking at the HW connections in the weir editor. You should see where the station isn’t increasing. Did you set GIS coordinates? sometimes you get a mis-click and weir doubles back on itself. Other times its a issue with not having the correct reach lengths or lateral not near end of XS and the XS projection crosses other XS.
