Welcome to the RAS Solution › Forums › HEC-RAS Help › Multiple Alternatives on One Plot
- This topic has 3 replies, 1,059 voices, and was last updated 11 years, 1 month ago by Anonymous.
August 6, 2015 at 12:02 am #5850AnonymousGuest
Hello.
This may be a very silly question, but I am a self-taught user and the only user in my office, so I am slowly discovering better ways to use HEC-RAS.
I have been modeling several alternatives and have what I would consider a good working knowledge of HEC-RAS. When I have an issue, I am often able to create a work-around of some kind.
I have seen cross-section plots showing the current conditions and the alternatives on one plot. However, I have been copying my current condition and creating a new project file altogether to run my alternatives. Is there a way I could get this cross-sectional information into one project file from the current situation I’m in?
Thanks!
August 6, 2015 at 12:36 am #9460sktseParticipantIf I’m understanding your question right, you’re exploring either alternatives in the geometry of your model (i.e. the effect of construction on the model), or alternatives in flow scenarios.
The way that HEC-RAS is structured allows both of these possibilities to be explored within a single project file.
A project file consists of geometries, flow scenarios, and plans (among other things).
A geometry file (*.g01, *.g02, etc.) will describe the physical features in your model, such as hydraulic structures and the channels in your model.
A steady/unsteady flow file (*.f01, *.f02, or *.u01, *.u02, etc.) describe the different flow scenarios (1:10 year return period, PMF scenarios, etc.).
A plan file (*.p01, *.p02) pairs a geometry file with a flow file to create the model that you want. So for example:
MyProject.p01 might consist of a pre-construction geometry (MyProject.g01) with a 1:60 year return period (MyProject.f01)
To see how construction might affect this, you would create a post-construction geometry file (MyProject.g02), and run it through your original 60-year flow file (MyProject.f01). You can save this to a new plan (MyProject.p02). That way, you can refer to both your original plan (p01) and your new plan (p02) without having to load an entirely new project file each time.
Organizing your alternatives along plans this way allows you to cross-section information that compares the two on a single plot (by going up to Menu Bar > Options > Plans… and checking off the appropriate plans).
If you are saving your geometries in separate projects, that’s okay — the HEC-RAS geometric data editor allows you to import HEC-RAS geometry files (*.g01, *.g02, etc.) into your project (by going to the Menu Bar > File > Import Geometry Data > HEC-RAS Format…)
At least that’s how I understand it. I hope that this helps you out.
Shawn
August 6, 2015 at 12:39 am #9461AnonymousGuestYes! Thank you. That is exactly what I am aiming to do. I figured there was a way to do it all in one project file. Thanks again for laying it all out for me.
August 6, 2015 at 3:43 am #9462Chris G.KeymasterReturn-Path:
Received: from mail-pd0-f173.google.com (mail-pd0-f173.google.com [209.85.192.173])
by mbob.nabble.com (Postfix) with ESMTP id 1CE2412A3E63
for; Wed, 5 Aug 2015 15:44:03 -0700 (PDT)
Received: by pdrg1 with SMTP id g1so24122269pdr.2
for; Wed, 05 Aug 2015 15:44:03 -0700 (PDT)
d=gmail.com; s=20120113;
bh=Q7WjmGhzDHBJ6ukINTx0SaudZ8TXaoJ3zMrLQddqFe0=;
b=jgmQfXqGuuc/sA0EH1ONo0EYJx6QRbbnld07WXK0sarvUiDBuYrSK+tb8+o5qjnNLJ
peATVWJq72tsSl7bFxaZxVPnjWh0Qu33dJysO72u4jqNlHcPU+2J+dB3S4wcfWbpLTal
yBymzpzRB8PYfZV9fOwORYPkvWydvk2DVhF89DI/RAvaB5i+071D2o8LNi9zBlr6kQMp
sTa+AQb8U5dPBcG0tmebQV896K/3hKVecv/Tbxx4BuU8IMzJOsQPbiL8H/IHORps5d+d
wFmyYS1mn0+h11PvZ2SEIkxc+qaDKlGIrFBhCbvplC0yvRZtl++CubShVA7hzarfly8z
3sFg==
X-Received: by 10.70.108.198 with SMTP id hm6mr24531310pdb.12.1438814643097;
Received: from [100.64.16.244] (59.sub-70-209-76.myvzw.com. [70.209.76.59])
by smtp.gmail.com with ESMTPSA id fk7sm576574pab.31.2015.08.05.15.44.00
for
Wed, 05 Aug 2015 15:44:01 -0700 (PDT)
Subject: Re: Multiple Alternatives on One Plot
boundary=Apple-Mail-E122E2C2-FF57-4FFE-9F2E-9DE491EFD816
X-Mailer: iPhone Mail (12D508)
Message-Id:
Date: Wed, 5 Aug 2015 15:43:58 -0700
To: “Julie [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-E122E2C2-FF57-4FFE-9F2E-9DE491EFD816
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableYou can import the RAS files from your other project. File…Import HEC-RAS D=
ata…Sent from my iPhone
> On Aug 5, 2015, at 12:02, Julie [via HEC-RAS Help]
wrote:
>=20
> Hello.=20
>=20
> This may be a very silly question, but I am a self-taught user and the onl=
y user in my office, so I am slowly discovering better ways to use HEC-RAS.=20=>=20
> I have been modeling several alternatives and have what I would consider a=
good working knowledge of HEC-RAS. When I have an issue, I am often able to=
create a work-around of some kind.=20
>=20
> I have seen cross-section plots showing the current conditions and the alt=
ernatives on one plot. However, I have been copying my current condition and=
creating a new project file altogether to run my alternatives. Is there a w=
ay I could get this cross-sectional information into one project file from t=
he current situation I’m in?=20
>=20
> Thanks!=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Multiple-Alternatives-on-One-Plo=
t-tp1890.html
> NAML–Apple-Mail-E122E2C2-FF57-4FFE-9F2E-9DE491EFD816
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitYou can import the RAS files from your other project. File…Import HEC-RAS Data…Sent from my iPhone
On Aug 5, 2015, at 12:02, Julie [via HEC-RAS Help] <[email protected]> wrote:Hello.
Thanks!
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/Multiple-Alternatives-on-One-Plot-tp1890.html
NAML
–Apple-Mail-E122E2C2-FF57-4FFE-9F2E-9DE491EFD816– -
