Welcome to the RAS Solution Forums HEC-RAS Help Modelling long culvert or bridge in HEC-RAS
  • This topic is empty.
  • #7695
    Deriham
    I plan to model a culvert (or bridge) with 300-meter length. Is HEC-RAS (as a 1D hydraulic model) appropriate to model long culvert as? I recognised that a long culvert will be modelled as pipe in open channel (I might be wrong). Any thoughts are appreciated.
    Another question is on entrance loss for culvert modelling in HEC-RAS. There is always a drop at the culvert inlet even the culvert is large enough to convey the flow. Is there an appropriate approach to reduce entrance loss? Any suggestions are welcome
    Thank you very much.
    #12838
    You could model the culvert/bridge as cross-sections with lids. If the water surface will never touch the low chord, then you could just ignore the culvert/bridge and just use cross-sections making sure to take into account roughness changes.
    As for culvert entrance losses, the manual provides different values based on different types of configurations. In reality, you should try and calibrate the losses based on actual flow data, but this does not happen often as there is usually no data.
    It is up to the modeler to decide if what they see in HEC-RAS is too much entrance loss or not and adjust as needed. This could be done by checking culvert losses in HY-8, culvert nomographs, hand calculations, or other software.
