Welcome to the RAS Solution › Forums › HEC-RAS Help › Modelling a waterfall
- This topic has 4 replies, 547 voices, and was last updated 7 years, 11 months ago by Anonymous.
April 16, 2018 at 6:17 pm #6855AnonymousGuest
Hi everyone,
I’m quite new to HEC-RAS and I’m writing my thesis, using modelling to estimate paleoflood discharges. What I’m specifically trying to model is a huge waterfall (Asbyrgi in Iceland). However, instead of being straight, it is a amphitheater-shaped canyon and I’m don’t have a good idea how to make cross sections for this. Anyone has an idea what would be the best solution for this?
Thanks in advance!
Eline
May 6, 2018 at 7:38 pm #11327Chris G.KeymasterYou should bend the cross sections to follow the shape of the amphitheater. Gradually transition back to straight cross sections as you move away from the waterfall. Cross sections should always be drawn and oriented so that they are perpendicular to the direction of flow, even if the direction of flow changes over the length of the cross section.
Then use an inline structure for the waterfall.Alternatively, you can model this with a 2D mesh and use a SA/2D Area connection for your waterfall.
May 7, 2018 at 12:03 pm #11328eline.steinbuschParticipantReturn-Path:
by sloti1d2t14 (Cyrus 3.1.3-348-ge94e049-fastmail) with LMTPA;
Mon, 07 May 2018 04:03:35 -0400
X-Cyrus-Session-Id: sloti1d2t14-1353913-1525680215-2-18300658936810057149
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 0.0
X-Spam-hits: BAYES_00 -1.9, RCVD_IN_DNSWL_NONE -0.0001, SPF_HELO_PASS -0.001,
SPF_PASS -0.001, URI_HEX 1.122, LANGUAGES en, BAYES_USED global,
SA_VERSION 3.4.0
X-Spam-source: IP=’104.47.1.90′,
Host=’mail-ve1eur01on0090.outbound.protection.outlook.com’, Country=’AT’,
FromHeader=’nl’, MailFrom=’nl’, XOriginatingCountry=’UNK’
X-Spam-charsets: plain=’iso-8859-1′
by compute1.internal (LMTPProxy); Mon, 07 May 2018 04:03:35 -0400
by mailmx.nyi.internal (Postfix) with ESMTP id 2C293C61BD
for; Mon, 7 May 2018 04:03:35 -0400 (EDT)
id 4E7BB2A8002;
1525680215; b=H6Ys0Uhgj8R81Y3FQ93aM9thB/owo6WD0fosMkqWzliUBwnJZX
5GDn214T/YRlXVW5v7fvZOXTh0ZFWssrwyCjhgb7yRR45wSBF9gkjYoaxp5xuCxz
RhfwO8TpCGlj9d1kCgzuBH4DgkLgct1QzOlJtoZoFs7x/FpVpf+n3Q7MsDjkOFhM
YQaerQSebPV3/n1ZE2KYm3GpFin9bN8hmQh1Mcr3XwbCcAoU/sGBiv2zkP7HEVfX
ODg2jZJAkp8jJZchwspTqqQSD6sQqd9v0h2iaeazJzgNlV4nQ8glgE32bt/96IQG
l1wr2+YA1DIq5gddsUtXOIg8JTXj4jDQZ7kQ==
messagingengine.com; h=from:to:subject:date:message-id
:references:in-reply-to:content-type:content-transfer-encoding
:mime-version; s=fm2; t=1525680215; bh=1VrjwdeOUw0nzrrojqGCcsaYm
ejAzAbo1f918tOMcAM=; b=jZRlsSzw07R1NIPscDPiq7ZObxRD8cS6goal+IiJg
FatVmPqkOoY2yENfzAGqAdhE/wkgSTIHX0Vvq+bwFT8J1Nl6eaL7lcomOmrpJows
vSy5m1gC5PH1YwoJCJbC/ePS0otWILgWe0sXabUEYFuKLLc6jlXx8N0ZPB+dqNGc
dVBcFf9VFyEZlvtPCsIsQ0MCLYxuDKfUC1vD18KlCAMR/dDsyQNSNv3fF4wYcIHd
ILmExZuVRgkeJyvkGJB38ni/njezW8VAKILzHZ/uObEa7MCOli3KCRvMDHi6x1Fn
w975swueiyGUUkTUp/rYh6hpqAHMSV1BwJlMCUVa0CaqA==
dkim=none (no signatures found);
dmarc=none (p=none,d=none) header.from=wur.nl;
iprev=pass policy.iprev=104.47.1.90
(mail-ve1eur01on0090.outbound.protection.outlook.com);
spf=pass [email protected]
smtp.helo=EUR01-VE1-obe.outbound.protection.outlook.com;
x-cm=none score=0;
x-ptr=fail x-ptr-helo=EUR01-VE1-obe.outbound.protection.outlook.com
x-ptr-lookup=mail-ve1eur01on0090.outbound.protection.outlook.com;
x-return-mx=pass smtp.domain=wur.nl smtp.result=pass
smtp_is_org_domain=yes header.domain=wur.nl header.result=pass
header_is_org_domain=yes;
x-tls=pass version=TLSv1.2 cipher=ECDHE-RSA-AES128-SHA bits=128/128;
x-vs=clean score=0 state=0
x-cm=none score=0;
X-ME-VSCategory: clean
X-CM-Envelope: MS4wfI7noHNR8yMtjdXrwZaiWAZwyE8AtyREh5qDBfJnyxKt3zCRQynI+4kJIuQrbJyvj2PJ++j1ZJmNCcbEctztj3FPxif3QsQLa+jtb01QmSwYo/159Fv5
D18yjz9/JwXHPS8DBUeQ1+TN+vGNcWFpGA+ku4eP+/JO+Jw6g25wB8gbvuNvNZ35nSoOFSK2iktPfrLpa8u5lT/Yabui6YtgQpijAtjhsmg42NnIaBGOPnio
o16yHl622EJos6gR0jLtfyW1Dqr2Q1JEYcYW9QQnMMo=
X-CM-Analysis: v=2.3 cv=NPP7BXyg c=1 sm=1 tr=0 a=Cy8LTVYY3X39oq5Xu1GCUA==:117
a=2nXtKh/iHPoWD7g7raZ6QQ==:17 a=sE2-r3R2ey8A:10 a=YEQtRoL_au8A:10
a=8nJEP1OIZ-IA:10 a=VUJBJC2UJ8kA:10 a=9I5xiGouAAAA:8 a=-9DQ5X9AAAAA:8
a=IFEzbUb9VLHWGXlVpGwA:9 a=ftPZu8ZOlwsE-ndn:21 a=7KKL9b8ei_wDs0VX:21
a=wPNLvfGTeEIA:10 a=9hKRvt0vAZUA:10 a=ARFN2YZ7Uv8kHtb7LS-q:22
a=_sbwFVlT91_TRwDTbSPC:22
X-ME-CMScore: 0
X-ME-CMCategory: none
Received-SPF: pass
(wur.nl: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:spf.protection.outlook.com’ matched))
identity=mailfrom;
client-ip=104.47.1.90
Received: from EUR01-VE1-obe.outbound.protection.outlook.com (mail-ve1eur01on0090.outbound.protection.outlook.com [104.47.1.90])
(using TLSv1.2 with cipher ECDHE-RSA-AES128-SHA (128/128 bits))
for; Mon, 7 May 2018 04:03:34 -0400 (EDT)
Received: from AM4PR0101CA0077.eurprd01.prod.exchangelabs.com
(2603:10a6:200:41::45) by DB7PR01MB4010.eurprd01.prod.exchangelabs.com
(2603:10a6:5:2b::15) with Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id 15.20.735.17; Mon, 7 May
2018 08:03:31 +0000
Received: from VE1EUR03FT062.eop-EUR03.prod.protection.outlook.com
(2a01:111:f400:7e09::208) by AM4PR0101CA0077.outlook.office365.com
(2603:10a6:200:41::45) with Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384) id 15.20.735.19 via Frontend
Transport; Mon, 7 May 2018 08:03:31 +0000
Authentication-Results: spf=pass (sender IP is 137.224.8.150)
smtp.mailfrom=wur.nl; n5.nabble.com; dkim=none (message not signed)
header.d=none;n5.nabble.com; dmarc=bestguesspass action=none
header.from=wur.nl;
Received-SPF: Pass (protection.outlook.com: domain of wur.nl designates
137.224.8.150 as permitted sender) receiver=protection.outlook.com;
client-ip=137.224.8.150; helo=mailedge.wur.nl;
Received: from mailedge.wur.nl (137.224.8.150) by
VE1EUR03FT062.mail.protection.outlook.com (10.152.18.252) with Microsoft SMTP
Server (version=TLS1_2, cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384_P384) id
15.20.715.13 via Frontend Transport; Mon, 7 May 2018 08:03:30 +0000
Received: from scomp5294.wurnet.nl (10.92.78.3) by scomp5306.wurnet.nl
(10.90.7.216) with Microsoft SMTP Server (TLS) id 15.0.1365.1; Mon, 7 May
2018 10:03:29 +0200
Received: from scomp5293.wurnet.nl (10.92.78.2) by scomp5294.wurnet.nl
(10.92.78.3) with Microsoft SMTP Server (TLS) id 15.0.1365.1; Mon, 7 May 2018
10:03:29 +0200
Received: from scomp5293.wurnet.nl ([10.92.68.2]) by scomp5293.wurnet.nl
([10.92.68.2]) with mapi id 15.00.1365.000; Mon, 7 May 2018 10:03:29 +0200
To: “Chris G. [via HEC-RAS Help]”
Subject: Re: Modelling a waterfall
Thread-Topic: Modelling a waterfall
Thread-Index: AQHT5VBW9fquNV5fOky4Ul3tBW2OTaQj6CVn
Date: Mon, 7 May 2018 08:03:28 +0000
Message-ID: <[email protected]>
References: <[email protected]>,<[email protected]>
Accept-Language: nl-NL, en-US
Content-Language: nl-NL
X-MS-Has-Attach:
X-MS-TNEF-Correlator:
x-ms-exchange-transport-fromentityheader: Hosted
x-originating-ip: [172.18.23.185]
Content-Type: text/plain; charset=”iso-8859-1″
MIME-Version: 1.0
X-EOPAttributedMessage: 0
X-Forefront-Antispam-Report:
CIP:137.224.8.150;IPV:NLI;CTRY:NL;EFV:NLI;SFV:NSPM;SFS:(10019020)(39380400002)(346002)(396003)(376002)(39860400002)(2980300002)(438002)(199004)(189003)(476003)(126002)(11346002)(2616005)(2900100001)(106002)(486006)(6116002)(3846002)(15974865002)(23756003)(356003)(336012)(76176011)(446003)(97736004)(77096007)(229853002)(6306002)(40036005)(68736007)(33896004)(102836004)(36756003)(186003)(7736002)(53936002)(305945005)(26005)(10126004)(413944005)(966005)(117636001)(478600001)(81156014)(8936002)(3480700004)(5660300001)(7116003)(6246003)(8676002)(8746002)(86362001)(50466002)(106466001)(316002)(97876018)(786003)(53416004)(69596002)(2906002)(74482002)(47776003)(81166006)(14454004);DIR:OUT;SFP:1102;SCL:1;SRVR:DB7PR01MB4010;H:mailedge.wur.nl;FPR:;SPF:Pass;LANG:en;PTR:InfoDomainNonexistent;A:1;MX:1;
X-Microsoft-Exchange-Diagnostics: 1;VE1EUR03FT062;1:tmoTufmF3h/ANtFEv/tilMY48b1DBDmJnhqab/Gq5QrZMExcE2LPQdHrdeloTK9d7FeyYVUFtPjNdJO3NvTFudd8ykt/U27Bd7BHKU48auOBDlwmv+knaU/VqHTGww51
X-MS-PublicTrafficType: Email
X-Microsoft-Antispam:
UriScan:;BCL:0;PCL:0;RULEID:(7020095)(4652020)(5600026)(4608076)(4534165)(4627221)(201703031133081)(201702281549075)(2017052603328)(7153060)(7193020);SRVR:DB7PR01MB4010;
1;DB7PR01MB4010;3:7tbgJXbPrVGklujKRb0pmgncPLPZg4SptKt9ekt0HKh5bsjUl0SaSZDfKzewkRQj10SqPZywN5xX78sdMH1hen5pXH5g5YoN/YqwFzqHOKy+u5ipyd3JvjuWta81jNK+amQ73Tdd+MJLKvvxc85utpU0SNt6p5Ej5j7jszVjaKpcA8SfMnVYjIKhXk7rJL+wMni90VIlX60F/lTugG8f3Ze9b0PJS/w83DWLMak6TFa3wAXd9g4RrgzmWGPdfatcE5vK26FAcZyN48Bm8lSxwHfTeUrNjYhnEE22UvJct4DyL6DLQdq4X4lr7jWsDlUTE7207ijqNJoSL7vCyH1UScRbhqsmGDN/E5T50bWc0eY=;25:gX+d/VG7h3EofxpNMySKcRc5JiN9dKaxVZfLWKbdkZ93UUFheEUnqsQ8eJh4hvpif7YkoZTgRDp5aEFKzx0Grb7S8Umgmdaszw3tTpE5IpJdmIrjkOKPREmeXBvXlrGPqEXaeZ02KNrpIVzp65oyIb2esJcH1nIlBujhtrt7+lXVMTnWgQF9/mMTw24JV4ZF6hwRwyWSEafluZ9CUkUPTVefVg42t7TqlfK9pdo/x05g5ckKS+kWiR8qYoH+zW/wPGZ0oTRsaz4a394TF3t5GgjV5BMZNqKRyb719sMxGl/k5hZ8bGn5Gk/8/USXMwZqLACMy2lbcRWTD3FSS9Z+kA==
X-MS-TrafficTypeDiagnostic: DB7PR01MB4010:
1;DB7PR01MB4010;31:ga/Q/9o/ksPRKNbMdChdBTp7syTDxjXCf7R7nNFSuZrduh5PeWwUQIurItLNbiUunTyFuuJryh2Kks7xj5yr/pSAVcr7RiHThjWv2YfAHgU4/ecoXbkNHfLnV33bnCDVv26SJM8ILvrtf1OE1++4LbT2EBU8nnzsIz9jXuv1wAx9g5tT7+uhH3+qYQ21nYWCXEXuz/uwx1yQmS3pUbY8JviKT8PwrzxgA9QFTfBwdJg=;20: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
X-Microsoft-Antispam-PRVS:
X-Exchange-Antispam-Report-Test: UriScan:;
X-MS-Exchange-SenderADCheck: 1
X-Exchange-Antispam-Report-CFA-Test:
BCL:0;PCL:0;RULEID:(6040522)(2401047)(5005006)(8121501046)(93006095)(93004095)(10201501046)(3002001)(3231254)(944501410)(52105095)(149027)(150027)(6041310)(20161123558120)(20161123564045)(201703131423095)(201702281529075)(201702281528075)(20161123555045)(201703061421075)(201703061406153)(20161123560045)(20161123562045)(6072148)(201708071742011);SRVR:DB7PR01MB4010;BCL:0;PCL:0;RULEID:;SRVR:DB7PR01MB4010;
1;DB7PR01MB4010;4:6dwExUaiymVcrcOQDaOHB4XbsCkExlx9aGrAhMpzTwCqUBa3RpCaoRSeWXINdfu24MW+R97kzqLlGyOhVxF0AbuUX38Ys/iGG0vpNlni5mvIrZtZvkNqM/YLrdMk7PHzrLkFf5ZtWaOyIlnE987TG0XpYjMmIve6+XTnVkCsUuBsZTDIL3DuHRwPCaaeaPngr6AyfOin/nXkR+TvMwXD2CQCCbvHoDrlaJfR4oZsUKS5xmR3RI1iDaHn2gemHF1lkUfsskuRJPhKqZs2Ifbczg==
X-Forefront-PRVS: 066517B35B
=?iso-8859-1?Q?1;DB7PR01MB4010;23:r5pHqtUDNpuheTkpS5+iT4PknqAhY/y5uAuvTAI?=
=?iso-8859-1?Q?d0WNl4dLut5Igk4dGP4wgJhYdjzLZJJF3xlNQs8CYj02Ohfzq6uiqupci/?=
=?iso-8859-1?Q?k2hEU6W/YqdGIJlui3ePXTOkdsiuDu375vT6oP6NkVSVrlv+t6lhYsu8Cp?=
=?iso-8859-1?Q?FUsjnZjlKs1xygehyImg+KIJDPX2Sb4WBy4u6i3OfNGi48ooCXddemXq5F?=
=?iso-8859-1?Q?QDosT4m25GDGUK+y6HHFo+LwqG4/9JEQK8LXCT3PdOsipEP2GymVP/e1ho?=
=?iso-8859-1?Q?IccCDODbnm8Sw9rVC1Etpdxyr7A9Bd21yYQ4iCGJMwHkYoEtVbH3HVOncT?=
=?iso-8859-1?Q?WEJd3Zy+oxYE9o6cBvws1Y4joKKkuWs+0wwwbVsawnyp1o1V+G4hleX8LZ?=
=?iso-8859-1?Q?LT1lrWxas/uuwjYO98zg80eafuHNIlzzKvYupjgzkGoQdBAwVFV8oRUGjf?=
=?iso-8859-1?Q?ttMSZeezPyRmLt2msiCxcehOTWZcCnoNLQce1oPALl0xKxpiSzDq7XUAN4?=
=?iso-8859-1?Q?c8nwhpgtyq+brhHb3XWmrX01YFGVTMEeaPLWeVwNPGovfh8K1RWwXr86zj?=
=?iso-8859-1?Q?ejuleuAdeqrR9aHlh1lV1qdkLArNf7ew4Xm4CxHEO/s1Ju3jpn+TPttQv/?=
=?iso-8859-1?Q?ku0+bYO9uNT0PyW41yK8lod+J0rRhO0HDAC9pmzTMGBosu1Vj6CKXzE1eC?=
=?iso-8859-1?Q?kASZzBAmfuoy+67laP+hfMQF0LZkInxcWfV6z+MoVz19XoXWLLe6D/PqmQ?=
=?iso-8859-1?Q?X1Y8T+LxZB1swGIm7h6cXyfRWSRXLbstWb6trMObGlPKKXKADo8vPSZklw?=
=?iso-8859-1?Q?Ut5ZWye7jiA6Ey2ZpukOsVJDytQDjjyT7OS8tSyZKU3bHGHIvGMU1Y71V4?=
=?iso-8859-1?Q?Zk+uJkfHyiWjTiOdZuGLVLoQyn7OyAN1OuPyAtvJWnDoeqAPK3OZsHP4l2?=
=?iso-8859-1?Q?dS5kf13I84L2xMRijHocnh3BRKewTK0eWhRMhjKbgTPYtM1SHQBnBpu3WO?=
=?iso-8859-1?Q?Kk+Qls68eoDFFKkjXcpt1qpHYNjoUXNx1k/oFiETXpKDtIw2o4/3j+wgql?=
=?iso-8859-1?Q?Cxn/sCKmRrPq6BrjBUbNLCFmwyL3ptjhZosYp9uz5g6nmbLfGJwA7x2uIO?=
=?iso-8859-1?Q?6VgkNucJ5ClEXQdHgswv4/6ij1G2+VJx0rFnjSushgyMsYQtvB4Hgl4swg?=
=?iso-8859-1?Q?4TcHu/D9E0248wC9/XMB8CNfly/srp9eBgDnQsYrsgONphwTJu6S2XfZZ2?=
=?iso-8859-1?Q?sV7N2fVWRWAgYphpUbNmP5DElSIlJrbffxxHMI3LtXG06NMcYOZKexw18z?=
=?iso-8859-1?Q?QRBSCPfGIXShqX0I2uwu4H8TkMuCq7Yn1Z95CK7UPWLfwzpRFF3hkbTtZE?=
=?iso-8859-1?Q?JTVG0mx1Qp3i6MiOxYwdegKpUXM6xAzKnnV51e4yYk9yZRPFw+2I/eii2T?=
=?iso-8859-1?Q?wWU8ymWZ7fF7TywZw5N/mVKI6naK+ti4+hHjG4Mv+2od2zqDYwvzmS1Sw?=
=?iso-8859-1?Q?=3D=3D?=
X-Microsoft-Antispam-Message-Info:
ZUWOEWNO22DCE7kdt0kw/sIkFNEx2BobucihpvczidJWHFyyIrYZBuSas1np15CE8K9/5VeA3kK9pR5WPxX2UuJZ+Xi2yjoDSTQxuBUKFr6XwRsSwpFyUw/z6CtiW4R2kfKbqV3GRLujpr+14qpzKrkxhf440i/2jHLFRetac2yAbFlZotKjh4vbYP/IzBTH
1;DB7PR01MB4010;6:Q0Kr4jkaTgF1rVnNX1Skc6GgAyGe2zBb7o+ywtH4D67i24WRfhUkvkgOpPLVVSlKBlIhNAVRCasThx33dRh5pmO5V5Juerxf5oKVTxh01m8Z5prH3wXxjy5NjXJJU26cdgfCcOsygzsl57v1pd3I8jQDKkajUZObdeN6AHfmlp3Mf3Cxdgmpa5zshl8wF9t9Uuv6xPjXxCiGdVy3mPw6oPF/ZPYIoekM+zMZutOrA0wJiBCYII0BSljvbQPx/WcYHkcfhMyIOAOWLl/nRX36jZq99KMAq+HQRB2ukQQQRoqs6Ro3B/ccd0bqkYpas8mS7Uc0/dUGmGoIQBwmWrFQRI4l5SzlxuG56cJ/v7AUOmuh6L+fwjM8X6IyEcrU+C7qU7X1yjI6cjkf6Xncfqc2ewCJ3n1Tzw500cvYKm+0q6oJnmUshIYMpmN6UzqqFn6T9q7aSozoMl5k2hjcsp7v4A==;5:1BdXMU/6IJ7EwQ5xS0i23xpx40cRDPoOFNgsDl3+xpDyCoP0kYh8R/k4Gksp6VueY5TPegC4pDSPjfka6dx4Gi350awWmiX4SKu/yOpQY/nXV4onCi7kTqCqiqyfusnYk5SS58tUSHG6DJoDeZdQNO/d3sKVu27ESnWo79MG31M=;24:0riKvUhKcPEjrCeyphVaMXCcqGs7+UOjnAJK1LY+OUYM/pM0TfmO0i02AEioAzA0Fdfmp9Dts/8A/OPoU3e7Ai0JZCE6Dhb23NND9BWHGjg=
SpamDiagnosticOutput: 1:99
SpamDiagnosticMetadata: NSPM
1;DB7PR01MB4010;7:rwkwgqW4n2gdV8fzHnKNOEDh84GBASNCTWYC/s7JvX2AVVquwl1Mny1vwYeThrwL+w+Mmu+Fd68WYf9ESgctoOvkR/on5nlETDoMXk3+1v+J3pGQ6Og1XUT0fP6h2UNsa7/vwPvz9+ARn429embWDUOQPes5QgUD6UZZMeXnxZIOx0AUKsXFk125ZsKJBgacGUJWiLYmtsxXe6uIUtkSMaTUKtlh93kBNnhc2K6crJJfDxeFxH8N92FD8UVHTooD
X-MS-Office365-Filtering-Correlation-Id: 11e66ffa-5929-4868-fc88-08d5b3f105e1
X-OriginatorOrg: wur.nl
X-MS-Exchange-CrossTenant-OriginalArrivalTime: 07 May 2018 08:03:30.8885
(UTC)
X-MS-Exchange-CrossTenant-Network-Message-Id: 11e66ffa-5929-4868-fc88-08d5b3f105e1
X-MS-Exchange-CrossTenant-Id: 27d137e5-761f-4dc1-af88-d26430abb18f
X-MS-Exchange-CrossTenant-OriginalAttributedTenantConnectingIp: TenantId=27d137e5-761f-4dc1-af88-d26430abb18f;Ip=[137.224.8.150];Helo=[mailedge.wur.nl]
X-MS-Exchange-CrossTenant-FromEntityHeader: HybridOnPrem
X-MS-Exchange-Transport-CrossTenantHeadersStamped: DB7PR01MB4010?Dear Chris,
Thank you very much for your answer, it is very helpful.
Kind regards,
Eline Steinbusch
Van: Chris G. [via HEC-RAS Help]
Verzonden: zondag 6 mei 2018 17:38
Aan: Steinbusch, Eline
Onderwerp: Re: Modelling a waterfallYou should bend the cross sections to follow the shape of the amphitheater.=
Gradually transition back to straight cross sections as you move away fro=
m the waterfall. Cross sections should always be drawn and oriented so that=
they are perpendicular to the direction of flow, even if the direction of =
Then use an inline structure for the waterfall.Alternatively, you can model this with a 2D mesh and use a SA/2D Area conne=
@RASModel
http://www.therassolution.com________________________________
low:
http://hec-ras-help.1091112.n5.nabble.com/Modelling-a-waterfall-tp5472p5561=
.html
To unsubscribe from Modelling a waterfall, click here<http://hec-ras-help.1=
091112.n5.nabble.com/template/NamlServlet.jtp?macro=3Dunsubscribe_by_code&n=
ode=3D5472&code=3DZWxpbmUuc3RlaW5idXNjaEB3dXIubmx8NTQ3MnwxNjE3ODA5NDkz>.
.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-na=
bble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespac=
e-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleName=
space-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.Nabble=
Namespace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subsc=
ribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_inst=
ant_email%21nabble%3Aemail.naml>July 19, 2018 at 4:28 pm #11329gerar200Participant– deleted –
July 25, 2018 at 4:35 pm #11330AnonymousGuestThis is correct
