Welcome to the RAS Solution › Forums › HEC-RAS Help › Modeling Storage behind a culvert
  • #5707
    pmur3774
    I’m having a problem I hope someone can point me in the right direction. I am trying to model a detention basin in steady flow (unsteady is really not feasible due to steep stream gradient). I ran the basin in HMS and received the peak inflow/outflow values. I then inserted the outflows into the RAS model at the cross section
    immediately downstream of the culvert outlet of the basin. When I ran the model I get results that do not match the inserted outflows. For example, at the 2yr event, the peak inflow to the basin is 78 cfs and the outflow from HMS is 65 cfs. The output in RAS shows the downstream flow to be 0.5 cfs. When I do not reduce the outflow and re-run the model the flows are the same (78 in and 78 out). This problem is similar
    when I run all the frequency flows. The output flows do not match the steady flow inserted values.
    Anyone run into this,or does someone have an answer as to how to fix this?
    Thanks in advance.
    #9127
    markwood
    Return-Path:
    Received: from na01-bn1-obe.outbound.protection.outlook.com (mail-bn1on0079.outbound.protection.outlook.com [157.56.110.79])
    by mwork.nabble.com (Postfix) with ESMTP id 30F57145DC1C
    for ; Thu, 19 Feb 2015 06:17:03 -0800 (PST)
    Received: from CO2PR03CA0050.namprd03.prod.outlook.com (10.141.194.177) by
    BL2PR03MB193.namprd03.prod.outlook.com (10.255.230.141) with Microsoft SMTP
    Server (TLS) id 15.1.93.12; Thu, 19 Feb 2015 14:16:54 +0000
    Received: from BN1AFFO11FD040.protection.gbl (2a01:111:f400:7c10::145) by
    CO2PR03CA0050.outlook.office365.com (2a01:111:e400:1414::49) with Microsoft
    SMTP Server (TLS) id 15.1.99.9 via Frontend Transport; Thu, 19 Feb 2015
    14:16:53 +0000
    Received: from USDEN3EXHT002.na.aecomnet.com (65.240.194.57) by
    BN1AFFO11FD040.mail.protection.outlook.com (10.58.52.251) with Microsoft SMTP
    Server (TLS) id 15.1.99.6 via Frontend Transport; Thu, 19 Feb 2015 14:16:52
    +0000
    Received: from USDEN3EXMB002A.na.aecomnet.com ([169.254.13.78]) by
    USDEN3EXHT002.na.aecomnet.com ([172.27.132.57]) with mapi id 14.03.0181.006;
    Thu, 19 Feb 2015 06:16:26 -0800
    To: “pmur3774 [via HEC-RAS Help]”
    Subject: RE: Modeling Storage behind a culvert
    Thread-Topic: Modeling Storage behind a culvert
    Thread-Index: AQHQTEzLOQLG9FuZEEWDmgLQCNOFV5z4A7Cw
    Date: Thu, 19 Feb 2015 14:16:26 +0000
    Message-ID: <6E5E1A75787CA14E9AB482FF2FFE6A715A71CCD6@USDEN3EXMB002A.na.aecomnet.com>
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    x-originating-ip: [172.27.154.247]
    x-aecom-disclaimer: Yes
    boundary=”_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71CCD6USDEN3EXMB002An_”
    MIME-Version: 1.0
    X-EOPAttributedMessage: 0
    Received-SPF: None (protection.outlook.com: aecom.com does not designate
    permitted sender hosts)
    Authentication-Results: spf=none (sender IP is 65.240.194.57)
    [email protected]; n5.nabble.com; dkim=none (message not
    signed) header.d=none;
    X-Forefront-Antispam-Report:
    CIP:65.240.194.57;CTRY:US;IPV:NLI;EFV:NLI;SFV:NSPM;SFS:(10009020)(428002)(189002)(377454003)(51874003)(199003)(105586002)(6806004)(106466001)(19580405001)(19580395003)(106116001)(512954002)(46102003)(107886001)(110136001)(50986999)(33656002)(55846006)(54356999)(76176999)(14971765001)(19625215002)(16236675004)(86362001)(87936001)(2656002)(92566002)(19300405004)(2900100001)(2950100001)(64706001)(62966003)(104016003)(77156002)(77096005)(2920100001)(84326002)(101416001)(450100001)(15975445007)(102836002)(5890100001)(19617315012);DIR:OUT;SFP:1101;SCL:1;SRVR:BL2PR03MB193;H:USDEN3EXHT002.na.aecomnet.com;FPR:;SPF:None;PTR:ip-65-240-194-57.den3.us.aecom.com;MX:1;A:1;LANG:en;
    X-Microsoft-Antispam: UriScan:;
    X-Microsoft-Antispam: BCL:0;PCL:0;RULEID:;SRVR:BL2PR03MB193;
    X-Microsoft-Antispam-PRVS:
    X-Exchange-Antispam-Report-Test: UriScan:;
    X-Exchange-Antispam-Report-CFA-Test:
    BCL:0;PCL:0;RULEID:(601004)(5005003);SRVR:BL2PR03MB193;
    X-Forefront-PRVS: 0492FD61DD
    X-Exchange-Antispam-Report-CFA-Test: BCL:0;PCL:0;RULEID:;SRVR:BL2PR03MB193;
    X-OriginatorOrg: aecom.com
    X-MS-Exchange-CrossTenant-OriginalArrivalTime: 19 Feb 2015 14:16:52.3785
    (UTC)
    X-MS-Exchange-CrossTenant-Id: f205a70a-ddf9-44aa-bf6c-2c222d9d1bfc
    X-MS-Exchange-CrossTenant-OriginalAttributedTenantConnectingIp: TenantId=f205a70a-ddf9-44aa-bf6c-2c222d9d1bfc;Ip=[65.240.194.57]
    X-MS-Exchange-CrossTenant-FromEntityHeader: HybridOnPrem
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BL2PR03MB193
    –_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71CCD6USDEN3EXMB002An_
    If I understand correctly, running a steady simulation (elevations computed=
    from downstream to upstream), I believe you need to use the HMS outflows a=
    t both the downstream and upstream face of the culvert, so that the culvert=
    experiences a single discharge.
    Should also be noted, if tailwater affects the performance of the outflow, =
    you may need to iterate between RAS and HMS using outflow curves in HMS for=
    the structure applying rating curves from RAS that capture the hydraulics/=
    tailwater downstream of the culvert, until elevations (and discharges) matc=
    hup between the two.
    From: pmur3774 [via HEC-RAS Help] [mailto:[email protected]=
    e.com]
    Sent: Thursday, February 19, 2015 9:02 AM
    To: Markwood, David
    Subject: Modeling Storage behind a culvert
    I’m having a problem I hope someone can point me in the right direction. I=
    am trying to model a detention basin in steady flow (unsteady is really no=
    t feasible due to steep stream gradient). I ran the basin in HMS and recei=
    ved the peak inflow/outflow values. I then inserted the outflows into the =
    immediately downstream of the culvert outlet of the basin. When I ran the =
    model I get results that do not match the inserted outflows. For example, =
    at the 2yr event, the peak inflow to the basin is 78 cfs and the outflow fr=
    om HMS is 65 cfs. The output in RAS shows the downstream flow to be 0.5 cf=
    s. When I do not reduce the outflow and re-run the model the flows are the=
    when I run all the frequency flows. The output flows do not match the stea=
    Thanks in advance.
    low:
    http://hec-ras-help.1091112.n5.nabble.com/Modeling-Storage-behind-a-culvert=
    -tp1327.html
    To start a new topic under HEC-RAS Help, email [email protected]=
    ble.com
    To unsubscribe from HEC-RAS Help, click here<http://hec-ras-help.1091112.n5=
    .nabble.com/template/NamlServlet.jtp?macro=3Dunsubscribe_by_code&node=3D1&c=
    ode=3DZGF2aWQubWFya3dvb2RAYWVjb20uY29tfDF8LTE3NzA3MjE4MzI=3D>.
    .naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-na=
    bble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespac=
    e-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleName=
    space-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.Nabble=
    Namespace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subsc=
    ribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_inst=
    ant_email%21nabble%3Aemail.naml>
    This e-mail and any attachments contain AECOM confidential information that=
    may be proprietary or privileged. If you receive this message in error or =
    are not the intended recipient, you should not retain, distribute, disclose=
    or use any of this information and you should destroy the e-mail and any a=
    ttachments or copies.
    If I understand correctly, ru=
    nning a steady simulation (elevations computed from downstream to upstream)=
    , I believe you need to use the HMS outflows at both the
    downstream and upstream face of the culvert, so that the culvert experienc=
    Should also be noted, if tail=
    water affects the performance of the outflow, you may need to iterate betwe=
    en RAS and HMS using outflow curves in HMS for the structure
    applying rating curves from RAS that capture the hydraulics/tailwater down=
    stream of the culvert, until elevations (and discharges) matchup between th=
    e two.
    [via HEC-RAS Help] [mailto:ml-node+[email protected]]
    To: Markwood, David
    I’m having a problem =
    I hope someone can point me in the right direction.  I am trying to mo=
    del a detention basin in steady flow (unsteady is really not feasible due t=
    in HMS and received the peak inflow/outflow values.  I then inserted =
    immediately downstream of the culvert outlet of the basin.  When I ran=
    the model I get results that do not match the inserted outflows.  For=
    example, at the 2yr event, the peak inflow to the basin is 78 cfs and the =
    RAS shows the downstream flow to be 0.5 cfs.  When I do not reduce th=
    e outflow and re-run the model the flows are the same (78 in and 78 out). &=
    nbsp;This problem is similar
    when I run all the frequency flows.  The output flows do not match the=
    Anyone run into this,or does someone have an answer as to how to fix this? =
    Thanks in advance.
    If you reply to this ema=
    il, your message will be added to the discussion below:
    ht=
    tp://hec-ras-help.1091112.n5.nabble.com/Modeling-Storage-behind-a-culvert-t=
    p1327.html
    ml-node+s109=
    [email protected]
    click here
    NAML
    This e-m=
    ail and any attachments contain AECOM confidential information that may be =
    proprietary or privileged. If you receive this message in error or are not =
    not retain, distribute, disclose or use any of this information and you sh=
    ould destroy the e-mail and any attachments or copies.
    –_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71CCD6USDEN3EXMB002An_–
