Thank you, Luis. Good point about perpendicular flow. The fence is oblique across the floodplain. Overbank flow is partially deflected, and the deflection would vary with stage. I did not give thought to flow direction with regards to a cell face. It seems full momentum ought to help with regard to vectors at the cell face, but, for flood plain modeling, diffusion wave ought to be sufficient. I am not familiar enough with 2D at a code level to knowledgeably switch the equation sets for this situation. What difference might a full momentum might make? How much of a problem would non-perpendicular flow be? Perpendicular flow would be an assumption, and without gauging specific to this fence – it is what it is. Reasonable?
