Thanks Luis. I have tried that before, in which I create a Storage Area, then I create two “C-shaped” 2D flow areas that together completely surround the storage area. The two flow areas also meet each other at the top and bottom ends of the “C”s.
It does get a bit tricky sometimes to get the two connections between the flow areas at the ends of the “C”s to work properly, unless there happens to be a convenient “ridge” like a roadway berm to act as the “border” connecting the two flow areas. Thus, why I wanted to know how others have approached this problem of laying out an upground reservoir in a flat area.
