Welcome to the RAS Solution Forums HEC-RAS Help Modeling a sharp channel drop
  • This topic has 1 reply, 301 voices, and was last updated 11 years ago by Anonymous.
  • #5571
    How would you go about modeling a sharp drop in a channel (e.g. concrete)? Say you have a 2′ drop over a 2′ distance. TIA!
    #8910
    Keymaster
    It depends. If your drop will be highly submerged (tailwater depth is appreciably higher than the brink elevation) then just model it with cross sections. One upstream of the brink, and one downstream. Otherwise, you might try using an inline structure.
