Welcome to the RAS Solution › Forums › HEC-RAS Help › model of small laboratory flume
- This topic has 4 replies, 580 voices, and was last updated 11 years, 7 months ago by Anonymous.
September 4, 2014 at 9:24 pm #5578AnonymousGuest
I teach a basic hydraulics course and would like to use RAS to model different flow scenarios in the small flume (width =100 mm, length = 4 meter, height = 300 mm). I have had some success with steep slope models (4% or greater, even including hydraulic jumps). The students collect flume data and add to the model for calibration. I would like to model mild slope scenarios with bridge piers inserted into the flume. I created a cross section at station 0 and copied it to station 4 with a downstream reach length of 4 m and adjusted the elevations for a slope of 0.5%. When using the interpolation feature to add additional cross sections, oscillations in the bed are shown due to the very small elevation changes and presumably storage limitations. Anyone have suggestions to get around this? Thanks!
September 4, 2014 at 9:44 pm #8920Chris G.KeymasterReturn-path:
Envelope-to: [email protected]
Delivery-date: Thu, 04 Sep 2014 09:45:29 -0700
Received: from mail-pa0-f54.google.com ([209.85.220.54])
by joe.nabble.com with esmtp (Exim 4.72)
(envelope-from)
id 1XPaA0-0004QG-1n
for [email protected]; Thu, 04 Sep 2014 09:45:29 -0700
Received: by mail-pa0-f54.google.com with SMTP id fb1so20179763pad.41
for; Thu, 04 Sep 2014 09:45:02 -0700 (PDT)
d=gmail.com; s=20120113;
bh=6d7zD4HVNWrgFhS7qBvyahWzgya3N26WbiUk08Usmxc=;
b=rlIsACAyD8yVKXbqh4WDUrrcxdF2IqnMDc/oP58GYz1XhIAMzFyJSsV0D+IUsr9OMm
f64WXMdq1jvQ3AUfQ5Fwqcs0wzmuSq97tqjjBnPXdkGK39Avwk4AlWrXMfx5BSOkHoIq
x6UMfFAlmtLesGQ9F2zLlK78+OZD/ki8+nwWB4oYHry+wVGHiuspT0Zfxz13czkw3IAX
wfdcabhriXi2QDRayjONtjHe9mt5un53GHKgduDTSyU/QhVPMDXMRElFJDaeKUjB1/01
J9Cuyc24KAtfA0wSjNtpgyrMyyx90Nh3YWr4wmWqlDO7UpIbAgH7tkGN7BCOEX9YK2BI
PlBA==
X-Received: by 10.66.240.197 with SMTP id wc5mr10299907pac.87.1409849102239;
Received: from [10.168.190.11] (134.sub-70-199-142.myvzw.com. [70.199.142.134])
by mx.google.com with ESMTPSA id ja3sm2091381pbd.73.2014.09.04.09.45.01
for
Thu, 04 Sep 2014 09:45:01 -0700 (PDT)
Subject: Re: model of small laboratory flume
boundary=Apple-Mail-CFBF2837-BADB-4AD7-91FD-08C12BC39685
X-Mailer: iPhone Mail (11D257)
Message-Id:
Date: Thu, 4 Sep 2014 09:44:58 -0700
To: “Jason Hill [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)
X-SA-Exim-Connect-IP: 209.85.220.54
X-SA-Exim-Mail-From: [email protected]
X-SA-Exim-Scanned: No (on joe.nabble.com); SAEximRunCond expanded to false–Apple-Mail-CFBF2837-BADB-4AD7-91FD-08C12BC39685
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableHi Jason-
Try this: http://hecrasmodel.blogspot.com/2008/12/extra-precision-in-interp=
olated-cross.htmlLet me know if it works.=20
ChrisSent from my iPhone
> On Sep 4, 2014, at 9:24 AM, “Jason Hill [via HEC-RAS Help]”
wrote:
>=20
> I teach a basic hydraulics course and would like to use RAS to model diffe=
rent flow scenarios in the small flume (width =3D100 mm, length =3D 4 meter,=
height =3D 300 mm). I have had some success with steep slope models (4% or=
greater, even including hydraulic jumps). The students collect flume data a=
nd add to the model for calibration. I would like to model mild slope scena=
rios with bridge piers inserted into the flume. I created a cross section a=
t station 0 and copied it to station 4 with a downstream reach length of 4 m=
and adjusted the elevations for a slope of 0.5%. When using the interpolat=
ion feature to add additional cross sections, oscillations in the bed are sh=
own due to the very small elevation changes and presumably storage limitatio=
ns. Anyone have suggestions to get around this? Thanks!=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/model-of-small-laboratory-flume-=
tp927.html
> NAML–Apple-Mail-CFBF2837-BADB-4AD7-91FD-08C12BC39685
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitHi Jason-Let me know if it works.ChrisSent from my iPhone
On Sep 4, 2014, at 9:24 AM, “Jason Hill [via HEC-RAS Help]” <[email protected]> wrote:I teach a basic hydraulics course and would like to use RAS to model different flow scenarios in the small flume (width =100 mm, length = 4 meter, height = 300 mm). I have had some success with steep slope models (4% or greater, even including hydraulic jumps). The students collect flume data and add to the model for calibration. I would like to model mild slope scenarios with bridge piers inserted into the flume. I created a cross section at station 0 and copied it to station 4 with a downstream reach length of 4 m and adjusted the elevations for a slope of 0.5%. When using the interpolation feature to add additional cross sections, oscillations in the bed are shown due to the very small elevation changes and presumably storage limitations. Anyone have suggestions to get around this? Thanks!
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/model-of-small-laboratory-flume-tp927.html
NAML
–Apple-Mail-CFBF2837-BADB-4AD7-91FD-08C12BC39685–July 16, 2015 at 11:37 pm #8921AnonymousGuestHello,
Sir, I have a query.
I am working with HEC-RAS for simulating my flume studies with a sand bed at the bottom.
Is it possible to get the bed elevation contour plots in Hec-Ras at the end of some flow happening for a particular period of time say 30 minutes or bed elevation changes?
If yes, please can u attach the procedure.
How were you able to get the bed oscillations you were mentioning?
and also how to set the bed to have the ripples pattern? I mean how to simulate it. it wold be nice if there is an example for flume studies.
A response and a set of instructions to follow would be largely helpful.P.S I assume that you have figured out about all you asked.
July 17, 2015 at 6:35 pm #8922AnonymousGuestI have used HEC-RAS to replicate a simulated dam break in a laboratory flume. The flume was a bit larger than the one that you are working with (4 ft. wide by 400 ft. long). My main interest was in comparing the HEC-RAS unsteady flow solution to a situation where the convective and local acceleration terms in the St. Venant equation were significant. A brief report is available at: https://www.dropbox.com/s/uuweuy72q18zmin/RAS%20replication.pdf?dl=0
MichaelOctober 27, 2019 at 3:38 pm #8923AnonymousGuestSir could you please share details of how you have modelled the flume used to simulate the dam break flow in a laboratory setup
Thank you.
