Welcome to the RAS Solution › Forums › HEC-RAS Help › Microstation TIN to HEc-ras Raster DEM (tiff)
  • #7179
    kabinluitel
    I have microstation TIN file and I need to develop a HEC-RAS model using RAS Mapper. Is there a way to convert that TIN into raster ?
    #12004
    Lonnie A
    This is how I do it. I’m not a microstation person so I have others do the export for me and it works coming from ACAD the same way:
    Export from microstation the TIN as a LANDXML then in GIS use the LANDXML file to import the TIN. Then under Arc Toolbox > 3D Analyst > Conversion > TIN to Raster: Give the output tin a name with a .tif extension. I keep the output type and method as default. Under sampling distance select the cellsize option and set the number to the size you want.
