Welcome to the RAS Solution Forums HEC-RAS Help Mesh issue in HEC-RAS 5.0.5 with importing structures
  • #6958
    andersonp
    Return-Path: Received: from compute1.internal (compute1.nyi.internal [10.202.2.41])
    by sloti1d2t14 (Cyrus 3.1.4-436-ge7b7449-fmstable-20180712v2) with LMTPA;
    Fri, 13 Jul 2018 14:15:03 -0400
    X-Cyrus-Session-Id: sloti1d2t14-1740832-1531505703-2-11013644046412893700
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 0.0
    X-Spam-hits: HTML_MESSAGE 0.001, ME_BETA_RULES 0.01, RCVD_IN_DNSWL_LOW -0.7,
    SPF_PASS -0.001, LANGUAGES en, BAYES_USED none, SA_VERSION 3.4.0
    X-Spam-source: IP=’148.163.159.7′, Host=’mx0b-00140302.pphosted.com’, Country=’US’,
    FromHeader=’com’, MailFrom=’com’, XOriginatingCountry=’US’
    X-Spam-charsets: plain=’us-ascii’, html=’us-ascii’
    Received: from mx6 ([10.202.2.205])
    by compute1.internal (LMTPProxy); Fri, 13 Jul 2018 14:15:03 -0400
    Received: from mx6.messagingengine.com (localhost [127.0.0.1])
    by mailmx.nyi.internal (Postfix) with ESMTP id 2E1A8428F7
    for ; Fri, 13 Jul 2018 14:15:03 -0400 (EDT)
    by mx6.messagingengine.com (Authentication Milter) with ESMTP
    id A941F52F2AD;
    1531505703; b=X4b3vTWD/IewpsoLuyMSL9QNrkiJRcrDA92wUPeerVfpXOSJdK
    yLZNiCdqjd0vC6C9jvZmOvX6946FO3d/TVCvWgCJBQpgfhTpS6X/nq793kPg2pI2
    uhhWOOn3R6yFfyCgQkp/RBV4QRj/aVw8R1a/8fkOOe76H+NYheYfZPPMm8b1f3Wt
    agEbgPW8cTpwxSs7vxHXAZHEq595J4XLt5/QE9xPDEYe/KhGcugMe9Oz0MrMEV/b
    +wsB/QZvq/17Y6Zeu2iViF3Rk4DWG8ziInffUIf3QPEXgBI0PlpOjOmnqlRFAiIn
    4jjShHZALSbtp5Td2eu3nE53RRR+l4dpVNwA==
    messagingengine.com; h=from:to:subject:date:message-id
    :content-type:mime-version; s=fm3; t=1531505703; bh=1bV2oQp3ThHu
    +TmDQGHkNZy6ZSbk54fhjgkEe/xJYZk=; b=V5JO5UdwemwnvhMpSUUV150xNjt0
    jopXuyVMEcOGKE4W4+a0pLbRlDv9tsV8Zx9pgEfyksLKHbgzp78SCNxtTkhZ2Aap
    evEWrHp0ht+M1mCCxv1uMSSln2ZJ/qt6Z7oO0VZVHLpvZanc42gqP0H90QAGBNpp
    X907bqJ6fuM0sJHYVnPL9niTwNpUqdnAbJROmYGMLsYge7XWrHZylw5EfXEbf7RJ
    hRe9up6D8v2Vzrgpqbq4158FCNLMSsviR3HgnMFSi8lKw9Z4127t1o3nc85Etc6a
    6is29Vscv2T8yqptHuazHylH9Fv2hi/9aTTKzMC8evcltqPWDpgoH2ASzw==
    ARC-Authentication-Results: i=1; mx6.messagingengine.com; arc=none (no signatures found);
    dkim=pass (1024-bit rsa key sha256)
    header.d=cdmsmithonline.onmicrosoft.com
    [email protected] header.b=L3214+3t
    header.a=rsa-sha256 header.s=selector1-cdmsmith-com x-bits=1024;
    dmarc=pass (p=none,sp=none,d=none) header.from=cdmsmith.com;
    iprev=pass policy.iprev=148.163.159.7 (mx0b-00140302.pphosted.com);
    spf=pass smtp.mailfrom=”[email protected]
    smtp.helo=mx0b-00140302.pphosted.com;
    x-aligned-from=domain_pass (Domain match);
    x-cm=none score=0;
    x-ptr=pass smtp.helo=mx0b-00140302.pphosted.com
    policy.ptr=mx0b-00140302.pphosted.com;
    x-return-mx=pass header.domain=cdmsmith.com policy.is_org=yes
    (MX Record found);
    x-return-mx=pass smtp.domain=cdmsmith.com policy.is_org=yes
    (MX Record found);
    smtp.bits=128/128;
    x-vs=clean score=0 state=0
    Authentication-Results: mx6.messagingengine.com;
    x-cm=none score=0;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    X-ME-VSCategory: clean
    X-CM-Envelope: MS4wfK9rDTEoATM/Zt3v+tDFlgCJh21OAmU8UNeycFoojmQNxEl4iUEVRqqhP3/5De1Gq6Y7RRi0TJejiEA8mYD0eIqcHHsUFdGxrVNEF04YdV35Lr8x2YwD
    +zduDWlBWDD6mRB3X+JfFWQCTr0+QOus3dosYlxA2iZiCgirrDrG8v2nrA+DI7ISAPfBZKzZtivu1E1nR4quiaf4LPaivdF+wdPlUM3hL3pO093GemSDAvH4
    o50m0HDt5NwYxd9hEFwqPA==
    X-CM-Analysis: v=2.3 cv=HoNY5XbS c=1 sm=1 tr=0 a=mo+mGfRWWEYvT82pWwMnvw==:117
    a=mo+mGfRWWEYvT82pWwMnvw==:17 a=avWb0JdZVfYA:10 a=Yr0UjgA97XgA:10
    a=UB5PfaEmDJ0A:10 a=xqWC_Br6kY4A:10 a=R9QF1RCXAYgA:10 a=H-6ciRE3H74A:10
    a=AQ13J6xDAAAA:8 a=0QNiVjuV6PtJe5W0qTEA:9 a=CjuIK1q_8ugA:10 a=rKGOI8JQbUEA:10
    a=HJu2tqQK-TEA:10 a=0mpAK2OOUkMA:10 a=yMhMjlubAAAA:8 a=SSmOFEACAAAA:8
    a=UuuDlNlMFRfekEU4:21 a=gKO2Hq4RSVkA:10 a=UiCQ7L4-1S4A:10 a=hTZeC7Yk6K0A:10
    a=frz4AuCg-hUA:10 a=7TB7PmmcGfPgxYLIyODY:22
    X-ME-CMScore: 0
    X-ME-CMCategory: none
    Received-SPF: pass
    (cdmsmith.com: 148.163.159.7 is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘mx’ matched))
    receiver=mx6.messagingengine.com;
    identity=mailfrom;
    client-ip=148.163.159.7
    Received: from mx0b-00140302.pphosted.com (mx0b-00140302.pphosted.com [148.163.159.7])
    by mx6.messagingengine.com (Postfix) with ESMTPS
    for ; Fri, 13 Jul 2018 14:15:01 -0400 (EDT)
    Received: from pps.filterd (m0097012.ppops.net [127.0.0.1])
    by mx0b-00140302.pphosted.com (8.16.0.22/8.16.0.22) with SMTP id w6DIEZXZ010307
    for ; Fri, 13 Jul 2018 14:15:00 -0400
    Received: from nam04-co1-obe.outbound.protection.outlook.com (mail-co1nam04lp0049.outbound.protection.outlook.com [216.32.181.49])
    by mx0b-00140302.pphosted.com with ESMTP id 2k6vrm96nr-1
    (version=TLSv1.2 cipher=ECDHE-RSA-AES256-SHA384 bits=256 verify=OK)
    d=cdmsmithonline.onmicrosoft.com; s=selector1-cdmsmith-com;
    h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck;
    bh=1bV2oQp3ThHu+TmDQGHkNZy6ZSbk54fhjgkEe/xJYZk=;
    b=L3214+3tGevtlnMV63/DWbyZkMhMFnfFxd2hdqW9CrH9bjrQ3QjeJioAN2QvOPvA0q6L/f//1/U3cO9+mzQ+X7u9zfJUbTtwyFBZD9U3IVd5Orqe0BnYARzAx5vciq0HnxoLdt9Q0QWPqA6+Qj2foubrcv4/NkEmGSFRH/Hq6Cs=
    Received: from BYAPR08MB4744.namprd08.prod.outlook.com (20.176.255.17) by
    BYAPR08MB5078.namprd08.prod.outlook.com (20.177.125.87) with Microsoft SMTP
    Server (version=TLS1_2, cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id
    15.20.930.21; Fri, 13 Jul 2018 18:14:57 +0000
    ([fe80::15d7:c35e:2b8d:bcfc]) by BYAPR08MB4744.namprd08.prod.outlook.com
    ([fe80::15d7:c35e:2b8d:bcfc%3]) with mapi id 15.20.0930.022; Fri, 13 Jul 2018
    18:14:57 +0000
    To: “[email protected]
    Subject: Mesh issue in HEC-RAS 5.0.5 with importing structures
    Thread-Topic: Mesh issue in HEC-RAS 5.0.5 with importing structures
    Thread-Index: AdQa1SZGcz8tV+AeTUC3fx9rpkcs7Q==
    Date: Fri, 13 Jul 2018 18:14:57 +0000
    Message-ID:
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    x-originating-ip: [66.151.131.6]
    x-ms-publictraffictype: Email
    x-microsoft-exchange-diagnostics: 1;BYAPR08MB5078;7:nQ6uv7XloYSD7GtdbJ/D5wDMqIzDYoiYOCxa2gB+JQnmfOQPRxqKVUfB/XF3N1X+Vq8YZhh0eW+88VPvkq2TPvFkkoaivrr50l7ehxo5yhBlGTJjIqViFGLCK3JbwzqSEmNyHojU1rISFzNDINQRFDH9WoQ7Px/IyIddaydmyOO16wYzpXkQmvolC/hZTRMSDqKr5s8tQqjIBPOh7lRZNZzC2Ght6l+Ns+dhCtEqp73HfhdF34Q6P4mPIRQ7JUtQ
    x-ms-exchange-antispam-srfa-diagnostics: SOS;
    x-ms-office365-filtering-ht: Tenant
    x-ms-office365-filtering-correlation-id: 313578cc-e3ba-41b0-a3db-08d5e8ec8a96
    x-microsoft-antispam: UriScan:;BCL:0;PCL:0;RULEID:(7020095)(4652040)(8989117)(48565401081)(5600053)(711020)(4534165)(7168020)(4627221)(201703031133081)(201702281549075)(8990107)(2017052603328)(7153060)(7193020);SRVR:BYAPR08MB5078;
    x-ms-traffictypediagnostic: BYAPR08MB5078:
    x-microsoft-antispam-prvs:
    x-exchange-antispam-report-test: UriScan:(28532068793085)(21748063052155)(218525252085611);
    x-ms-exchange-senderadcheck: 1
    x-exchange-antispam-report-cfa-test: BCL:0;PCL:0;RULEID:(8211001083)(6040522)(2401047)(8121501046)(5005006)(3231311)(944501410)(52105095)(10201501046)(93006095)(93001095)(3002001)(6055026)(149027)(150027)(6041310)(20161123560045)(20161123564045)(201703131423095)(201702281528075)(20161123555045)(201703061421075)(201703061406153)(20161123562045)(20161123558120)(6072148)(201708071742011)(7699016);SRVR:BYAPR08MB5078;BCL:0;PCL:0;RULEID:;SRVR:BYAPR08MB5078;
    x-forefront-prvs: 07326CFBC4
    x-forefront-antispam-report: SFV:NSPM;SFS:(10009020)(136003)(396003)(376002)(346002)(366004)(39850400004)(199004)(189003)(252514010)(8676002)(68736007)(478600001)(66066001)(33656002)(2906002)(25786009)(6306002)(14454004)(316002)(55016002)(6436002)(54896002)(236005)(81156014)(9686003)(105586002)(99286004)(86362001)(106356001)(5250100002)(5660300001)(2900100001)(81166006)(476003)(55236004)(74316002)(7696005)(7736002)(256004)(790700001)(97736004)(3846002)(8936002)(6506007)(102836004)(6116002)(26005)(53936002)(186003)(486006);DIR:OUT;SFP:1101;SCL:1;SRVR:BYAPR08MB5078;H:BYAPR08MB4744.namprd08.prod.outlook.com;FPR:;SPF:None;LANG:en;PTR:InfoNoRecords;A:1;MX:1;
    received-spf: None (protection.outlook.com: cdmsmith.com does not designate
    permitted sender hosts)
    x-microsoft-antispam-message-info: ZdB9kDPjubbdb9oIUQER6z0VkfFlm6HiwSssX9to6NJRSLEW+6Q4NUqxd81zl6XtWORlFQqmvlEQdNYZIkOg+A4vjhrxy0ORlzKnDteoV0dbII3POo8aMp5d4x+iGYA4zJFPovdeAkZTqXwqG+JT/jMHS1vb4FJAyMVcPjN49YZkMz6A38bjUdgpeMrQqnYy20tm52PHR6yg4XT0milLrhyNAXYq8yStGdJd4hJLDrMsnVMEh4rvs6fvU4JIfsxHcwwL/astONve7L0a1rCbOdI8oCvH17w+XrixIGj5KMtpamnDjPBiljCsQk+Wq4APP4vw2xfXonfPWQ8TT/S/H2xNS59Ytj9JxoBrbZ8+2i0=
    spamdiagnosticoutput: 1:99
    spamdiagnosticmetadata: NSPM
    boundary=”_000_BYAPR08MB4744EE77F7B5B8C746CFE370CA580BYAPR08MB4744namp_”
    MIME-Version: 1.0
    X-OriginatorOrg: cdmsmith.com
    X-MS-Exchange-CrossTenant-Network-Message-Id: 313578cc-e3ba-41b0-a3db-08d5e8ec8a96
    X-MS-Exchange-CrossTenant-originalarrivaltime: 13 Jul 2018 18:14:57.6015
    (UTC)
    X-MS-Exchange-CrossTenant-fromentityheader: Hosted
    X-MS-Exchange-CrossTenant-id: 330a8b8c-66ba-485c-bddd-3beeb7f55fe8
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BYAPR08MB5078
    X-Proofpoint-Virus-Version: vendor=fsecure engine=2.50.10434:,, definitions=2018-07-13_06:,,
    signatures=0
    X-Proofpoint-Spam-Details: rule=cdmsmith_outbound_notspam policy=cdmsmith_outbound score=0
    priorityscore=1501 malwarescore=0 suspectscore=0 phishscore=0 bulkscore=0
    spamscore=0 clxscore=1011 lowpriorityscore=0 mlxscore=0 impostorscore=0
    mlxlogscore=544 adultscore=0 classifier=spam adjust=0 reason=mlx
    scancount=1 engine=8.0.1-1806210000 definitions=main-1807130161
    –_000_BYAPR08MB4744EE77F7B5B8C746CFE370CA580BYAPR08MB4744namp_
    I imported structures from another HEC-RAS 5.0.4 model and just clicked on =
    ones I wanted. I got to recompute mesh and it gives no cells and says it w=
    as produced in red in bottom left or says it with : and then won’t compute =
    mesh and I have to start over.
    Paul Anderson, P.E., CFM
    CDM Smith, a member of Compass PTS JV
    Telephone: 303-383-2418
    Email: [email protected]
    I imported structures from another HEC-RAS 5.0.4 mod=
    el and just clicked on ones I wanted.  I got to recompute mesh and it =
    gives no cells and says it was produced in red in bottom left or says it wi=
    th : and then won’t compute mesh and I
    have to start over.
    Paul Anderson, P.E.=
    , CFM
    CDM Smith, a member=
    of Compass PTS JV
    Telephone: 303-383-=
    2418
    Email:
    [email protected]
    <= /span>
    –_000_BYAPR08MB4744EE77F7B5B8C746CFE370CA580BYAPR08MB4744namp_–
    #11514
    Does it say there is an error with the mesh? Did you have both Mapper and the Geometric Editor open at the same time?
