Welcome to the RAS Solution Forums HEC-RAS Help merge two models
  • #6132
    Keming
    I have two Hec-Ras 1D models established for two sub-catchments. Can anyone kindly advise how to merge two models into one model by connecting them to a river channel at downstream?
    Regards,
    Keming
    #9970
    GoSparky
    Sounds like you need to put in a stream junction. See chapter 6 of the Users Manual and Example 10 in Applications Guide.
    #9971
    If you have two separate models that are in different RAS projects that you want to combine into a single model, the easiest way to do this is probably the import geometry function. From the Geometry editor, select File, Import Geometry Data…
    #9972
    Keming
    Thanks for your advice
    #9973
    rskgautam
    In addition to import geometry function, you need to make sure the initial and boundary conditions. In some instances, if you have one model developed for simulation period different than the other model, then, all IC/BC are required to be updated accordingly.
    I have gone through detail merging two HEC RAS procedures. We call it ‘stitching HEC RAS models’. If you have more than two storage areas and would like to use RAS 2D, condition becomes more challenging.
    #9974
    Hi Rskgautam.
    I saw your reply to this questions. And I have the save problem. Somehow, after importing the geometry, the crossings were assigned to the original river reach, insteading of appending the whole river reach and cross section upstream. Do you know what is causing this? and how could I fix it?
