Welcome to the RAS Solution › Forums › HEC-RAS Help › Maximum number of 2D cells
  • #6575
    Hi i tried create relativly big model with lots of 2D cell, but my project crashed. Is there some limitation of maximum number of 2D cell? Or it it dependes of my hardware cunfiguration? If yes what is the most
    important parameters? Amount of ram memory? Thank you.
    #10802
    My understanding is that there is currently a maximum limit of around a million cells.
    #10803
    Chris G-M
    Is your ‘around a million’ cell limit based on experience or a known programming limitation? Triangulating a mesh with ~2.2 million cells is feasible in the geometry editor but a memory exception is thrown during the ‘Compute 2D Flow Areas Hydraulic Tables’ command. Definitely not a hardware limitation (128GB DDR4 RAM) but I’m curious if this limitation will persist or if others have found a work-around for larger models. Any hints or clarification would be appreciated.
    Best regards,
    #10804
    It is a software issue. I think the limitation will persist unless HEC updates the program to handle more data.
    The idea behind how HEC-RAS deals with the geometry is supposed to allow for bigger cells that give the same results as smaller. Which should mean that you should not need 2 million elements. Depending on what you are trying to accomplish this can be true, but for very detailed models this does not always workout.
