Welcome to the RAS Solution Forums HEC-RAS Help Max Depth with no values
  • #6529
    Hi all,
    It’s possible vai RAS Mapper create a Map of Max Depth without values less a fixed values?
    Antonio
    #10713
    Chad Ballard
    Not within RAS that I know of. There is no option for a ‘No Fill’ in the contouring. You would have to export to a program like ArcGIS that has that contouring option.
    #10714
    Lonnie A
    Under tools in RASMapper, Render Mode Options you can set a minimum depth to plot.
    #10715
    Thank you a lot for help!
    Regards
