Welcome to the RAS Solution Forums HEC-RAS Help Map layer not aligning to geometric data
  • This topic has 3 replies, 105 voices, and was last updated 6 years ago by Anonymous.
  • #7571
    I have added a map layer using google satellite images in rasmapper. However, the channel on the map is not aligning to that from the terrain model I have used to plot my geometric data. Would anyone know how i can try get these to match?
    #12681
    Scott Miller
    I take it the entire channel is offset by the same distance and direction. Is that right? How far is it off?
    What projections are the terrain and image data in? Check to see if a datum transformation is needed.
    #12682
    Did you try the Bing Maps? I have seen this happen occasionally with Google Maps.
    #12683
    benp
    Problem solved here with square pixel instead of rectangular.
    http://hec-ras-help.1091112.n5.nabble.com/Problem-with-misaligned-spatial-projection-prj-British-National-Grid-td3753.html#nonehttp://
    I don’t know if this solve your problem.
