In Rasmapper verify your changes are being updated on the cell faces (right click on the cell face and select property table).
What I have to do some times is within the geometry window in 2d area edit mode modify a n-value and save the file. Then modify it back to what you want in order for RAS to recognize a change has occurred and needs to reprocess the cell faces. So then select force mesh recomputation and back in RASmapper select the compute 2D hydraulics table. After it has ran verify the changes are applied to the cell face.
I find when you change the land classification RAS likes to revert back to the default n-value across the entire 2D area and there is no way to know this without digging into it in mapper.
