Welcome to the RAS Solution Forums HEC-RAS Help Mannig´s values (downstream routing of dam break wave)
  • #5732
    Robert
    I want to ask you: What conditions (high mannig´s value from 0.10 to 0.18, ineffective areas or block obstructions) do you enter for the built-up area/developed areas, when do you solve a downstream routing of dam break wave using 1D?
    How do you solve a the developed areas in the 2D model, when you have only digital terrain model (no digital surface model)? (applied to downstream routing of dam break wave)
    In nowdays I use high mannig´s values for the built-up-area.
    (see you annexes)
    https://drive.google.com/folderview?id=0B6wWUzbPUM0dWm1JeUlZc0lIU28&usp=sharing
    thank you very much
    Robert
