Welcome to the RAS Solution Forums HEC-RAS Help LWD structures in 2D Areas
  • #6226
    Has anyone modeled Large wood (or other flow deflection) structures in a 2D area? I am considering modeling them as a structure with a very high roughness value for the cell or possibly adding them directly into the terrain. Any input or suggestions would be greatly appreciated.
    Thanks ahead of time!
    #10125
    Lonnie A
    Either method would work. You will still get a larger than actual volume stored in the high n-value method. Be aware that RAS will only assign one n value per cell face so you need to define your mesh or n value accordingly. RAS is taking which ever n value makes up the largest % of the cell face length as the value it assigns.
