Welcome to the RAS Solution Forums HEC-RAS Help Low Flow Dam Break in Series
  • #6173
    Hello there! Anybody up for a puzzle?
    I have an unsteady flow HEC-RAS model where we have 2 dams in series, where the upstream dam is modeled as a storage area, and the downstream dam is modeled using dynamic storage through cross sections.
    I have run a PMF storm through the model, once without breaking the upstream dam and once with breaking the upstream dam. If the downstream dam is overtopped, I breach the structure and use Froehlich Method parameters. The model runs fine with the high flows.
    When I do the same with an SDF storm (100-year intensity), and breach the downstream dam when it is overtopped, the model crashes on the cross sections directly downstream of the downstream dam.
    I have tried everything I have read on blogs and forums for gaining stability on a low flow unsteady dam breach model, including:
    -Check Boundary Conditions
    -Check Ineffective Flow Areas
    -Check Htab parameters
    -Check Dam Breach Parameters
    -Use Interpolated Cross Sections
    -Modeled with and without downstream tributaries
    -Adjusted Computation Intervals
    -Make sure the bottom slope is steady
    -Re-modeled the plans
    -Adjusted Calculation Options and Tolerances
    -Adjusted pilot flow of inline structures
    -Use a Pilot Channel
    What am I missing?
    A link to the model is provided here:
    https://www.dropbox.com/sh/0s7wt6z90wf34av/AABUWgruH5C14i3kr6mjqHvoa?dl=0
    Any help if very much appreciated!!
    -Jim M
    #10024
    Jim: I found that using a wider (5 ft.) and rougher (n=0.1) pilot channel helped. Also got rid of section 1078.42 based on it being too close to the bounding sections. RAS 5.0.1 completed the run at a time step of 5 seconds, but I didn’t look at the results. Might consider these suggestions.
    #10025
    Thank you Michael! I will absolutely look at that solution! Thank you for your suggestion!
