My little model isn’t working properly. At cross section 1 it looks all good but then down the river the steady flow analysis results in a velocity loss and so the height of my water line is going way up…
What could be wrong?
And I get similar results like the official hazard map of the country hazard management (for a 100yearly flood) but my flow is only like 10% (1 m3/s) of the 100yearly flood (10.4 m3/s)!?!?
I put manning n to 0.04 for the whole area. My lower BC is normal depth (0.02) and my upper BC is a flow hydrograph (in 30 minutes from 0.05 m3/s to 1 m3/s and then back to 0.05 m3/s in 90 minutes). Delivering Slope is again 0.02.
I put the lower and the upper BC only in the mesh cell exactly where the deepest point of my flume is.
I think it might be related to your upstream BC, delivering slope being 0.02, you should increase that value gradually, maybe try 1 and see the difference. I didnt experience myself but I remember seeing it in one of the posts in this blog and this adjustment solved the problem.
Good luck!
