Welcome to the RAS Solution Forums HEC-RAS Help Levees_IneffectiveFlowAresa
  • This topic has 2 replies, 677 voices, and was last updated 12 years ago by Anonymous.
  • #5352
    I would like to ask someone a question about inserting Levees and Ineffective Flow Areas through Cross Section Editor in HEC-RAS 4.1. I have inserted Levees and In. Flow. areas to every cross section (in HEC RAS 4.1). Then I have started a simulation. Everything was OK, all levees and IFA were on right places. Then I have exported all files to HEC GeoRAS.
    Problem was during postprocessing in HEC-GeoRAS. Resulted inundation areas were without Levees and IFA (disappeared). Program has not detected levees and IFA points. I really dont know where is the problem. I have checked export setup (export from HEC RAS to HEC Geo RAS) – everything was OK.
    Is it problem of export or I have to create a levee and IFA layers during preprocesing in HEC GeoRAS? Please I need an advice 🙂 Thanks
    #8545
    Keymaster
    In the GIS Export window, there’s Additional Properties located in the lower right-hand corner where you can select Levees and Ineffective Areas. Hopefully that will help.
    Good Luck
    @RASModel
    #8546
    emtithal
    please, I need to know where I have put levee or ineffective area
