Welcome to the RAS Solution Forums HEC-RAS Help Layer Setup Blank Fields
  • This topic has 1 reply, 217 voices, and was last updated 12 years ago by Anonymous.
  • #5460
    Has anyone had a problem with fields in the layer setup (under RAS Geometry) for GeoRAS defaulting as blank? That is, there are no options in the pull-down menu. Specifically, this is the case for the storage points, levee points, and bank points fields. I have none of these things in my model. All other fields at least have “Null”. When I hit OK to exit the layer setup, I get an error and can’t proceed.
    I’ve tried starting with a blank map, brand new geodatabase, and computer restart. Starting with a blank map has got me around this problem in the past, but not this time. I’m using GeoRAS 4.3.93 for Arc 9.3.
    Thanks!
    #8724
    Finally got it to work by starting a new GeoRAS workmap (.mxd) in a brand new folder. This did not entirely solve the problem, but would be interested to hear if any one else has had this problem / found a work around.
