Welcome to the RAS Solution Forums HEC-RAS Help Lateral Stucture Split Flow Optimization Failure
  • #5689
    CPDPEC
    I am relatively new to HEC-RAS.
    I am working on a residential development that partially lies within a floodplain. I was given the 100-yr flowrate for the main floodway channel by local FP authorities. The ultimate goal of this exercise is to ensure imported fill is not raising the 100-yr WSEL. The proposed grading creates a ridgeline which divides the FP at the top. I am trying to model the ridge as a lateral structure letting water from the main channel overflow into the side channel which eventually ties back in to the main floodway at the bottom of the FP. I have created the lateral structure and directed the overflow to my side channel reach. When I run a steady state flow the lateral split flow optimization fails to converge. Checking the details of the structure shows it passes more water than was entered into the system and flows the wrong direction. If I discharge the weir flows out of the system I receive no errors, however, the weir flows seem high. I have searched the manuals and forums and I think my weir is set up correctly therefore I am not sure where my error is. I have provided a link to my project folder as well as a plan view of the project. All comments/suggestions related to this project are welcomed. Thank you in advance.
    http://www.dropbox.com/sh/c6rfp7zxcpffvss/AAAN2_EPBhldaRb-q788SNNNa?dl=0
    #9091
    a few things I noticed,
    1. XS 90883.06 does not appear to be in the correct location in plan view. As I scrolled through past this cross-section it jumped (skipped) multiple cross-sections.
    2. There should probably be some ineffective flow areas added to the model, the locations I noticed were around 71602. This will help increase the water surface elevation which should also help stabilize it.
    3. you should add weir stationing at HW cross-sections in the lateral structure options as the locations where the cross-sections intersect the lateral structure should be based on actual location and not the reach length.
    4. A better initial guess for the split flow in the flow options might help
    5. The last thing you could try is to run the model in unsteady mode with a constant hydrograph. This is more stable sometimes and also has the option of adjusting stability coefficients to make it more stable if needed.
    #9092
    CPDPEC
    Return-Path:
    Received: from na01-bn1-obe.outbound.protection.outlook.com (mail-bn1bon0091.outbound.protection.outlook.com [157.56.111.91])
    by mwork.nabble.com (Postfix) with ESMTP id D275E129800C
    for ; Mon, 2 Feb 2015 11:26:31 -0800 (PST)
    Received: from CO2PR0701MB1013.namprd07.prod.outlook.com (25.160.10.143) by
    CO2PR0701MB1015.namprd07.prod.outlook.com (25.160.10.145) with Microsoft SMTP
    Server (TLS) id 15.1.75.20; Mon, 2 Feb 2015 19:26:21 +0000
    Received: from CO2PR0701MB1013.namprd07.prod.outlook.com ([25.160.10.143]) by
    CO2PR0701MB1013.namprd07.prod.outlook.com ([25.160.10.143]) with mapi id
    15.01.0075.002; Mon, 2 Feb 2015 19:26:21 +0000
    Subject: RE: Lateral Stucture Split Flow Optimization Failure
    Thread-Topic: Lateral Stucture Split Flow Optimization Failure
    Thread-Index: AQHQPqPt4L2zurW+90+Iy+R+DOrujpzdhkdw
    Date: Mon, 2 Feb 2015 19:26:20 +0000
    Message-ID:
    <[email protected]>
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach: yes
    X-MS-TNEF-Correlator:
    x-originating-ip: [209.210.241.44]
    authentication-results: n5.nabble.com; dkim=none (message not signed)
    header.d=none;
    x-microsoft-antispam: BCL:0;PCL:0;RULEID:;SRVR:CO2PR0701MB1015;
    x-exchange-antispam-report-test: UriScan:;
    x-exchange-antispam-report-cfa-test: BCL:0;PCL:0;RULEID:;SRVR:CO2PR0701MB1015;
    x-forefront-prvs: 0475418F50
    x-forefront-antispam-report: SFV:NSPM;SFS:(10009020)(36304003)(377454003)(62966003)(106116001)(46102003)(77156002)(2900100001)(66066001)(16601075003)(450100001)(122556002)(76576001)(575784001)(33656002)(2656002)(19625215002)(86362001)(87936001)(99286002)(19300405004)(110136001)(54206007)(50986999)(76176999)(54356999)(16236675004)(99936001)(2950100001)(107886001)(19617315012)(18206015028)(19627595001)(19580405001)(54606007)(102836002)(15975445007)(40100003)(92566002)(74316001)(19580395003);DIR:OUT;SFP:1101;SCL:1;SRVR:CO2PR0701MB1015;H:CO2PR0701MB1013.namprd07.prod.outlook.com;FPR:;SPF:None;MLV:sfv;LANG:en;
    Content-Type: multipart/related;
    boundary=”_004_CO2PR0701MB1013A52E85EE682B2772FE0D983C0CO2PR0701MB1013_”;
    type=”multipart/alternative”
    MIME-Version: 1.0
    X-OriginatorOrg: performance-ec.com
    X-MS-Exchange-CrossTenant-originalarrivaltime: 02 Feb 2015 19:26:20.9174
    (UTC)
    X-MS-Exchange-CrossTenant-fromentityheader: Hosted
    X-MS-Exchange-CrossTenant-id: 3fab1324-f0f4-4851-8afe-f6748a701db2
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: CO2PR0701MB1015
    –_004_CO2PR0701MB1013A52E85EE682B2772FE0D983C0CO2PR0701MB1013_
    boundary=”_000_CO2PR0701MB1013A52E85EE682B2772FE0D983C0CO2PR0701MB1013_”
    –_000_CO2PR0701MB1013A52E85EE682B2772FE0D983C0CO2PR0701MB1013_
    Thanks for your response Cameron.
    I removed the erroneous cross-section and adjusted my weir structure statio=
    ning to reflect its actual profile. I changed my distribution of the weir =
    flows to “over multiple xs” and entered in the weir station intersections f=
    or the side channel cross-sections. When I attempt to run the steady flow =
    analysis with the lateral flow optimization turned on the program begins th=
    e calculations but then stalls. It produces no errors and I am forced to h=
    it the stop button to terminate the computation. I have read that during a=
    steady flow analysis the program will typically hang up on the cross-secti=
    on of error (i.e. bridge/culverts sections) however in my case it is the ve=
    ry first cross-section with fairly simple geometry. I attempted to input a=
    n unsteady flow as you mentioned but it produced similar results with the p=
    rogram locking up mid-calculation. The program runs with flow optimization=
    turned off but this doesn’t allow the flow of water between the reaches. =
    Any suggestions? I have posted a link to the project folder. Thank you.
    https://www.dropbox.com/sh/ju0qnt0x4ppibal/AACc0pHceARQPCtWBGw889Lka?dl=3D0
    Craig Dalton, P.E.
    [email protected]
    (406) 459-8456
    [PEC LOGO-page1]
    2101 Overland Ave * Billings, MT 59102
    http://www.performance-ec.com<http://www.performance-ec.com>
    This message is for the sole use of the intended recipients and may contain=
    confidential and privileged information. Any unauthorized review, use, dis=
    closure or distribution is prohibited. If you are not an intended recipient=
    , please contact the sender by reply e-mail and destroy all copies of the o=
    riginal message. E-mail attachments may contain viruses which could damage =
    your computer. While we have taken precautions to minimize this risk, we ca=
    nnot accept liability for such damage and you should carry out your own vir=
    us checks before opening an attachment. Thank you for your cooperation.
    From: cameron [via HEC-RAS Help] [mailto:[email protected]=
    .com]
    Sent: Sunday, February 01, 2015 9:51 PM
    To: Craig Dalton
    Subject: Re: Lateral Stucture Split Flow Optimization Failure
    1. XS 90883.06 does not appear to be in the correct location in plan view. =
    As I scrolled through past this cross-section it jumped (skipped) multiple=
    cross-sections.
    2. There should probably be some ineffective flow areas added to the model=
    , the locations I noticed were around 71602. This will help increase the w=
    3. you should add weir stationing at HW cross-sections in the lateral stru=
    cture options as the locations where the cross-sections intersect the later=
    5. The last thing you could try is to run the model in unsteady mode with a=
    constant hydrograph. This is more stable sometimes and also has the optio=
    low:
    http://hec-ras-help.1091112.n5.nabble.com/Lateral-Stucture-Split-Flow-Optim=
    ization-Failure-tp1278p1279.html
    To unsubscribe from Lateral Stucture Split Flow Optimization Failure, click=
    here<http://hec-ras-help.1091112.n5.nabble.com/template/NamlServlet.jtp?ma=
    cro=3Dunsubscribe_by_code&node=3D1278&code=3DY3JhaWdAcGVyZm9ybWFuY2UtZWMuY2=
    9tfDEyNzh8LTE1NDQ1MDc1NA=3D=3D>.
    .view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nabble%=
    3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabb=
    le%3Aemail.naml>
    I removed the erroneous cross-section=
    and adjusted my weir structure stationing to reflect its actual profile.&n=
    bsp; I changed my distribution of the weir flows to
    “over multiple xs” and entered in the weir station intersectio=
    ns for the side channel cross-sections.  When I attempt to run the ste=
    ady flow analysis with the lateral flow optimization turned on the program =
    begins the calculations but then stalls.  It produces
    no errors and I am forced to hit the stop button to terminate the computat=
    ion.  I have read that during a steady flow analysis the program will =
    typically hang up on the cross-section of error (i.e. bridge/culverts secti=
    ons) however in my case it is the very
    first cross-section with fairly simple geometry.  I attempted to inpu=
    t an unsteady flow as you mentioned but it produced similar results with th=
    e program locking up mid-calculation.  The program runs with flow opti=
    mization turned off but this doesn’t allow
    the flow of water between the reaches.  Any suggestions?  I have=
    https://www.dropbox.com/=
    Craig Dalton, P.E.
    [email protected]
    (406) 459-8456
    3D"PEC
    2101 Overland Ave
    Billings, MT 59102
    w=
    This message is for the so=
    le use of the intended recipients and may contain confidential and privileg=
    ed information. Any unauthorized review, use, disclosure
    or distribution is prohibited. If you are not an intended recipient, pleas=
    e contact the sender by reply e-mail and destroy all copies of the original=
    message. E-mail attachments may contain viruses which could damage your co=
    to minimize this risk, we cannot accept liability for such damage and you =
    should carry out your own virus checks before opening an attachment. Thank =
    ilto:ml-node+[email protected]]
    To: Craig Dalton
    a few things I notice=
    d,
     As I scrolled through past this cross-section it jumped (skipped) mul=
    2.  There should probably be some ineffective flow areas added to the =
    model, the locations I noticed were around 71602.  This will help incr=
    ease the water surface elevation which should also help stabilize it. &nbsp=
    3.  you should add weir stationing at HW cross-sections in the lateral=
    structure options as the locations where the cross-sections intersect the =
    lateral structure should be based on actual location and not the reach leng=
    th.
    4. A better initial guess for the split flow in the flow options might help=
    constant hydrograph.  This is more stable sometimes and also has the =
    option of adjusting stability coefficients to make it more stable if needed=
    If you reply to this email, your mes=
    sage will be added to the discussion below:
    http://h=
    ec-ras-help.1091112.n5.nabble.com/Lateral-Stucture-Split-Flow-Optimization-=
    To unsubsc=
    click here.
    N=
    AML
    –_000_CO2PR0701MB1013A52E85EE682B2772FE0D983C0CO2PR0701MB1013_–
    Content-Type: image/jpeg; name=”image001.jpg”
    Content-Description: image001.jpg
    Content-Disposition: inline; filename=”image001.jpg”; size=2844;
    creation-date=”Mon, 02 Feb 2015 19:26:20 GMT”;
    modification-date=”Mon, 02 Feb 2015 19:26:20 GMT”
    Content-ID:
    /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAoHBwkHBgoJCAkLCwoMDxkQDw4ODx4WFxIZJCAmJSMg
    IyIoLTkwKCo2KyIjMkQyNjs9QEBAJjBGS0U+Sjk/QD3/2wBDAQsLCw8NDx0QEB09KSMpPT09PT09
    PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT3/wAARCAAkAMUDASIA
    AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA
    AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3
    ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm
    p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA
    AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx
    BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK
    U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3
    uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwCTxNqv
    iqHxNqMdlPqq2yzERiJGKgcdOOlZf9s+Mv8An41n/v2/+Fe60tTym6rJK3Kjwn+2fGX/AD8az/37
    f/Cop/EXiu1UNcX+qQqTw0gZR+or3uub+IDRr4I1MSFRujAXd3bcMY96OUqNZNpcqOT+H3jfU77W
    00vVJvtKTKxjkYAOrAZwSOoIBr0J9b0uN2R9Ss1ZTgqZ1BB/OvF/h5/yPOnfV/8A0Bq2dFspbnUN
    caGx0G4xfyAnUiQwOTwvHShMdWnHmZ6pb6jZ3au1rdQTCP75jkDBfrg8VD/b2k/9BSx/8CE/xqrb
    WWm2el3f9nQWULvCfOFqFAJ2nrj8a8y0OU6Z4Ngv5vCdjqFqrMGu3Kl/vH7w2kgDpmncyjBSuevx
    XltcQGeG4ikhGcyI4KjHXkVX/t7Sf+gpY/8AgQn+Ncn4R06Sz8Ia1csLVIr4yzwx20m9EUp0z+mP
    asjwNpD3uk6b5/hfTbiyfIe+kdTIRk87cZ4PFFw9mtddj0g6pYi2Fyb22+zk7RL5q7CfTOcVF/b2
    k/8AQTsf/AhP8a47xxpthZz+GbOO2t4bI6h88QULHg4zkdPWtHWdG8LR6Jfvb2ekiZbeQoUVMhtp
    xj3ouLkVk+51L3lvFbC4kniSAgHzWcBcHpz0qt/b2k/9BSx/8CE/xrgLnn4ExZ/55r/6Nqlqco0/
    T7a2vPCGlW/2yERxXjSLtDFeCW2/Ke/JouUqVz1SS8tobcXEtxEkBxiRnAU56c9KmBBGR0rzzX9L
    k034TWmn3bI7xtCjlDkcyDofxpI9S8QaCW8KRRNc3kny6det91Ye7P7oP6e2S5Ps7rRnoEVzBPJJ
    HDNHI8R2yKrAlD6EdqS4vLe02faZ4od52r5jhdx9Bnqa4r4dWS6ZqniW081pPIuUUyv1c4OWP45r
    A1rVbHxXrF/LfQahLYwxNb6e1tbNIofPzS5HfIGPai41T963Q9ZJAGT0qOC5huohLbzRyxno8bBg
    fxFcx4I8RPregSQXu5dRsl8qdXGGPHytg+o/UGuR8J2GtaV4eh13QHNyju4utPfpIFYjcn+1gfX6
    9KLh7Pe7PVVuYGuHt1mjM6AM0YYblB6EjrUEusadbytHNf2kci8FHmUEfgTXF+ENYg174garqFsj
    osllEpRxhlYHBB+hqv4T0/Rb3UfEL6vBYyyDUZAhuQpOM9s0XD2dr3PQLa/tL3d9kuYJ9v3vKkDY
    +uKhbXNLRyr6lZqynBBnQEH86wPD1r4etfF+ppo5ZLvyU82KMAQhOMFcDGc9efWuO0GylubvWGhs
    dAuAL+QFtSJDjnovHSi4Kmnc9Wtr61vQxtLmGcL94xSBsfXFFVtJs9Ms43GmQWcJbBlFsFAJ98fj
    RTM2eJ+MZpV8Y6sFlkAFweA59BT7Twl4lvrSK5trS4khlUOjicDcD0PLVD4y/wCRy1b/AK+D/IV6
    94TvYofCOkq2SfsqZwOnFQldnbObhBNHln/CD+K/+fC5/wDAhf8A4qkbwJ4pkwH02dvTdMh/9mr2
    mR45jlo7j2wCBTNsP/PK5/WnymP1mXY4bwF4C1DStYXVNWCQmJSIoVYMxJGMkjgcZrfufA2m3NzL
    NJpWmO0jlizB8kk5yea2tsP/ADyuf1qN4nkIEEMq+7MadjOVWTdynpvhtNHSdNOs9Pt1nAEoRX+c
    DPXn3NIkaeH7SHT4o7OGBw2yCOGR8jq3Azxz+tatvZMhDyyMSOig8VDqmjpqc9tMZfLe33bP3auO
    cdmB54FFiHJvczNP0u20+2uIrGPTreGcAzRAuow3AypPy56dBU1gY9MtxYWM+lQxQBsRK5+QDlu/
    bnNWLjw5b3Upnmll+0MY90q4UsFxweOQccj8sVG/hpJDIHu5/KZZlCAAACTOe3ONxxmiwczZHqVh
    HrUP2fUU0u6RJAu18na+OnXg4PSsVfCnhsqXWz0IqpGWDNgZ6fxV0R8OWv2xbpXkWUTidipAD4GA
    rDuB27ioU8Lxppq2X2uUxI6yJ8oyCv8AOjlGptbMrzW1ncaZHpUraObKRVEdvuIVhnjAB9R+dWLm
    3W9sWsbk6XNbeX80TEkBF4z16Ajr2xU03h6K4mSeeeVpkEYyDtU7GLDKjg9e/oKZN4XtJomVpJg5
    RkWRSAybmZjg477yCDwRRYXMyn/Z1mbNNGP9ltArAramRjhh8wwM598VfvL24sXj+0y2is+QmI3Y
    8cnp29aUaEovlnW6lCLN5/lAADdgA89ccUuqaEmqXCStczRMqbQY8bl5zlT1VvcUWC5Um01NPt9Q
    uJIrGKO7+a7YCT95njnBz3xx603TrqKxsRbWclha29thBG6PEEzyBhsdea1JtMWfSBYPK+0IqiQA
    bvlwQfTsKgbR5pCHk1Gd5klEiOUTCYUrgLjHIY0WC7KcNnC2pPqUB0s3c8RDzIzZdBgHPOCBgDPa
    n6fGmlRR6fYSaXAucpCjHq3PAznnrUj+GbeWPE00rS4kxMuFZWdtxYYHHXGOmOuacvh2JL+K6WeQ
    eWUO0ADO1doye/AosF2Qw2SWt/LqEI0uO5uUG+ZcgyLkYPXnkjn6VmX3hvRbvUpDe2uiNeSHc4Ys
    GJ65IzWsPDS+QImvZmEcSwxHYo2KGVh255UdatnS/MbfcXDyyGF4C20LlWIPQdxijlGpNGXpOkWu
    jGU6VFpNuX2rIY85OfugnPfPHrmqH/CKaHf3cmLPRZ7hmZnAZixOeTjPqa2x4atBLHKHlWVHibep
    ALBAoCt6j5AfY9MU+x0MWN1HKLqV1iRkjjIAABOecdcUcoc73GaF4ftdDWcWlna23nFS32cMN2M9
    cn3orYoosJtvVnmuu+CbC/129upbi7V5pSzBWXAPtla7bQNNg0/R7OGPc4jiCqz8nAoooRtVb5Ua
    lFFFMwCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA//Z
    –_004_CO2PR0701MB1013A52E85EE682B2772FE0D983C0CO2PR0701MB1013_–
