Welcome to the RAS Solution › Forums › HEC-RAS Help › lateral structure not showing in cross section
  • #16221
    belis Kal
    Hi, is there any way to display lateral structure in cross section editor? This will help a lot to check whether the lateral structure has been placed in the highest elevation of the cross section.
    As far as i understand how these structures work,
    with the procedure above, the flow is transferred to 2d-flow area, only if the stage surpass highest ground.
