Welcome to the RAS Solution Forums HEC-RAS Help LATERAL STRUCTURE
  • #5553
    Orlando
    I’m using a culvert as a lateral structure but can’t get it to run. it’s steady state run and the model just locks up. I get the following results. any thoughts are appreciated.
    “error determining outpout format
    Overflow”
    #8875
    Does the model run if you remove the culvert/lateral structure? Is the lateral structure correctly set up?
