Welcome to the RAS Solution › Forums › HEC-RAS Help › Lateral outflow
Could you help me in telling how to model a lateral constant outflow out of the system.
You have to use rule as boundary condition
Is this a 1D model? If so, you can add a lateral inflow and then specify the flow using negative numbers.
@jarvus: Yes, its a 1D Model, however, I tried inserting flows in negative values but it doesn’t work. Have you tried it before?
@PaoloP: I appreciate any help in writing this rule
I just tried it in RAS 5.0.7 and it worked. I used the ‘Lateral Inflow Hydrograph’ and specified a flow of -100.0 and it appeared to remove the appropriate amount of flow.
I have same question.And i try to put pump station to model but it’s still not work.Anyone else can give another suggestion?
Please enter an answer in digits:
