  • #6047
    In hec ras 5.0, I am getting the error, “failure: too many command options. Cropping landuse.tif” for land cover layer. Project projection and raster projection are okay.
    #9816
    Vince Moody
    I encountered this error a while back, so my recollection might be a little fuzzy…
    If I recall, I had the option selected to import the landuse for only the active view or maybe the limits of the model geometry. This told the program that I wanted to clip the dataset I was importing, and that’s what made it blow up; like the program was trying to do too many things at once and didn’t like it.
    To resolve this, I clipped the landuse dataset externally (i.e. within GIS) and then imported to RAS Mapper, leaving that clipping option unselected.
    #9817
    Thanks Vince!! It worked great !!! 🙂
    #9818
    sprousegw
    I just had the same error and sure enough this fixed my problem as well. Thanks!
    #9819
    Just the same problem.
    It is fixed, many thanks!
    Best Quang
