Welcome to the RAS Solution Forums HEC-RAS Help Junctions and Reverse Flow
  • #6515
    maputnam
    I am modeling a diverging reach which has a diverging reach with a tidal boundary condition on the downstream end of each diverging reach. I am expecting negative flow from the tidal boundary condition and for some reason the negative flow will not translate through the junction. Will HEC-RAS accomodate negative flows through a junction?
    Thanks in advance,
    #10667
    I have data sets with a flow split and reverse flow through a junction that work.
    Do you have any special options turned on at the junction? Momentum, energy balance?
    #10668
    maputnam
    Momentum and Energy Balance
