I am running a 2D model in HEC-RAS with some embankments including as lateral structures. I am having some issues in the consideration of the embankments as I created a lateral structure with 300 m high and still the water is overtopping the embankment.
I do not know where is the error because the model runs correctly until the end. Has someonce faced a similar problem? Or do you know what are the common issues in considering embankments inside of a 2D mesh?
I could not upload here a printscreen of the conection editor of the embankment.
Thank you
