Welcome to the RAS Solution Forums HEC-RAS Help Issue with Ras mapper
  • This topic has 1 reply, 106 voices, and was last updated 7 years ago by Anonymous.
  • #7047
    Has anyone run in to an issue with ras mapper. I’m trying export all the results to make maps in ArcGIS. The only thing that gets made is the Depth and WSEL layers. when I try to click on velocity it says it needs computed, but when you recompute to generate the map it doesn’t do anything. Same with trying to generate just about any other map/layer like inundation boundary (which is what I really need). This has never been an issue before, only with this project.
    #11745
    Lonnie A
    You might try deleting the plan hdf file and while at it delete the folder that goes with that plan that RAS writes the static maps to and re-run the model.
