Welcome to the RAS Solution › Forums › HEC-RAS Help › Is there a way to display 2D cell elevation either on Mapper or geometry?
  • #7325
    I am trying to display the cell elevations. I can only find a way to display cell number.
    #12295
    You can display minimum cell elevation along each face using the Geometry Layer properties editor in Ras Mapper – maybe that’s enough information for your work?
    #12296
    Lonnie A
    If you are in Mapper, have the geometry 2D flow area active, you can right click on a cell or other feature and select plot property tables. From there you have a number of items that you can view including the cell elevations
