Welcome to the RAS Solution Forums HEC-RAS Help Is it possible to change the format of flood depth map (“tif instead of *flt) from RAS Mapper?
  • #5906
    nguyenduy1133
    Dear all,
    I am wondering if it is possible to change the format of flood depth map (“tif instead of *flt) from RAS Mapper? Because I need import flood depth map to PostGIS, unfortunately, PostGIS has not supported *flt format.
    I am looking forward to hearing from all of you!
    Best!
    Liem
    #9523
    version 5.0 outputs *.tifs for flood depths.
