Welcome to the RAS Solution Forums HEC-RAS Help Irregular shape Block Obstruction at a 1D cross-section
  • #17061
    Kinagoto
    Hi HEC Modelers,
    Any ideas on how to enter irregular shape Block Obstruction at a 1D cross-section in HEC-RAS?
    Thanks for your guidance.
    Nan
    • This topic was modified 3 years, 2 months ago by Kinagoto.
    #17064
    Luis Partida
    Hi, I think I just responded to your question on Linkedin as well. In this instance that level of detail is rarely needed and would not impact results much by having a pier with odd shapes. Select a worst case scenario and model that. If you truly want that odd shape the use cross sections with Lids and create the entire shape.
