Welcome to the RAS Solution Forums HEC-RAS Help Invert Stationing
  • This topic has 3 replies, 335 voices, and was last updated 8 years ago by Anonymous.
  • #6548
    I am trying to find the stationing of the channel invert. I see the variable ‘Center Station’ as an option in the output tables, but in spot checking it does not seem to correlate. I am unclear on how it is determining this variable. Is it just the station directly between what is set as the bank stations?
    Is there a way to find the invert stationing in table format?
    Thanks!
    #10749
    Jake G
    Hi Lauren,
    You should be able to use the table variable “Min Ch El Sta”. Note that if there are multiple points at the same invert elevation, then I believe it takes the rightmost point for the station.
    Good luck,
    Jake G.
    #10751
    Or where the centerline is hitting the cross section maybe? Which isn’t necessarily in line with the channel invert of the cross section editor.
    #10750
    Perfect! That’s exactly what I was looking for. Missed it in the search.
    Thanks!
