Welcome to the RAS Solution Forums HEC-RAS Help inundation shape disapears ins GIS
  • #6100
    Hey everyone. Did anyone had problems to work with the shapefile of the inundation boundary layer in an alternitive GIS after export (I use QGIS). My attribut table is empty and the polygon Layer has just one object. After working for a while with the polygon layer (deleting some points..) i can’t see the layer anymore. Just if i zoom out and the whole polygon is visible. Anyone an idea?
    #9926
    QGIS has issues sometimes. Can you save the edits you made and open the shapefile in another program?
    #9927
    I opend the shapefile in another GIS Program. There everything seems to be normal and I can zoom in and out and see my polygon the hole time. I saved the polygon shapefile with another name and opend it again in Qgis. Then i have the same problem again. I don t know if it is a problem from Qgis or what is wrong.
    #9928
    In QGIS save the shapefile out as a new one and see if that fixes it.
