Welcome to the RAS Solution Forums HECRAS Controller Interact with intermediate variable during the run
  • This topic has 1 reply, 142 voices, and was last updated 7 years ago by shen.
  • #8223
    shen
    Hello all, I was wondering whether it is possible to interact with model (e.g. get and set input variables or get output variables) WHILE the model is running, through HECRAS Controller. I checked the API functions and do not see find such a function.
    Alternatively, can I use hotstart file and set model simulation duration for a very short period (say 1 min) and keep rolling with hotstart file until the end of simulation? However, I am not sure whether the hotstart file is designed for such application. In other words, if I break my duration 10 hours into 5 sections or 50 sections using hotstart file, will the final results be exactly the same? I guess it depends on whether the RAS model uses previous step results for calculation for next time step. Could anyone kindly comment on this?
    Thank you for your inputs.
    Hailiang
    #13601
    shen
    Just following up on this post. Anyone who has performed a similar task and can share your experiences?
    With my best regards,
    Hailiang
