Anytime I use HEC RAS I bump into the same problem: is it someway possible to inspect and check results while the simulation is running?
Checking if the simulation is going good while running instead waiting for the end of the run would be very practical and will save a lot of time.
Is there any app\progrma written for example in MATLAB to do this job?
Alessandro
You just have to know based on the computations options and tolerances what is an unacceptable error and stop it when you see that. Remember though the error that is showing is JUST the error at 1 specific location (XS/Cell) and that specific time. There are times when i will see an error go above 1.0 and i let it continue because globally that error may be just fine.
