Welcome to the RAS Solution › Forums › HEC-RAS Help › Inline Structure
- This topic has 2 replies, 735 voices, and was last updated 12 years, 8 months ago by Greg Garrison.
August 12, 2013 at 10:43 pm #5340Greg GarrisonParticipant
I am trying to simulate flood flow in a trapezoidal concrete channel with full spanning flash boards that are perpendicular to the flow path. I am currently using inline structures to mimic the flash boards.
Does HEC-RAS assume a zero approach velocity for the weir equation used to predict flow over the flash boards and if so, would that have a significant impact on the predicted WSE’s from RAS?
Thank you in advance for any assistance,
GregAugust 17, 2013 at 3:45 am #8522AnonymousGuestThe standard weir equation does not have an approach velocity, so no, I do not think RAS is taking it into account.
I’m not sure how much difference it would make. How high of velocities are you expecting? I don’t have any specific suggestions but you could adjust the weir coefficient value to try and account for the approach velocity.August 17, 2013 at 3:48 am #8523Greg GarrisonParticipantReturn-path:
Envelope-to: [email protected]
Delivery-date: Fri, 16 Aug 2013 15:48:20 -0700
Received: from smtp120.ord1c.emailsrvr.com ([108.166.43.120])
by sam.nabble.com with esmtp (Exim 4.72)
(envelope-from)
id 1VASod-0004P3-RP
for [email protected]; Fri, 16 Aug 2013 15:48:19 -0700
Received: from smtp8.relay.ord1c.emailsrvr.com (localhost.localdomain [127.0.0.1])
by smtp8.relay.ord1c.emailsrvr.com (SMTP Server) with ESMTP id 45D6B1A0119
for; Fri, 16 Aug 2013 18:48:19 -0400 (EDT)
X-SMTPDoctor-Processed: csmtpprox 2.7.4
Received: from localhost (localhost.localdomain [127.0.0.1])
by smtp8.relay.ord1c.emailsrvr.com (SMTP Server) with ESMTP id 416321A019D
X-Virus-Scanned: OK
Received: by smtp8.relay.ord1c.emailsrvr.com (Authenticated sender: gregg-AT-watways.com) with ESMTPSA id C9CA31A0119
for; Fri, 16 Aug 2013 18:48:18 -0400 (EDT)
To: “‘jarvus lunt [via HEC-RAS Bloggery Forum]'”
Subject: RE: Inline Structure
Date: Fri, 16 Aug 2013 15:48:41 -0700
Message-ID: <004401ce9ad2$c1600c30$44202490$@com>
MIME-Version: 1.0
boundary=”—-=_NextPart_000_0045_01CE9A98.15013430″
X-Mailer: Microsoft Office Outlook 12.0
Thread-Index: Ac6a0lpaoGznSG/SSsySZPp4BUQgXgAAETBw
Content-Language: en-us
X-SA-Exim-Connect-IP: 108.166.43.120
X-SA-Exim-Mail-From: [email protected]
X-SA-Exim-Scanned: No (on sam.nabble.com); SAEximRunCond expanded to falseThis is a multi-part message in MIME format.
——=_NextPart_000_0045_01CE9A98.15013430
Content-Type: text/plain;
charset=”us-ascii”
Content-Transfer-Encoding: 7bitThanks for the response. I am seeing some pretty high velocities in the
channel, so I would assume the effect would be negligible if there was one.Thanks again,
Greg K. Garrison
Staff Engineer
Waterways Consulting, Inc.
403 Swift St. Suite B
Santa Cruz, Ca. 95060
(831) 421-9291
http://www.watways.com <http://www.watways.com/> / [email protected]
[mailto:[email protected]]
Sent: Friday, August 16, 2013 3:46 PM
To: Greg Garrison
Subject: Re: Inline StructureThe standard weir equation does not have an approach velocity, so no, I do
the weir coefficient value to try and account for the approach velocity._____
If you reply to this email, your message will be added to the discussion
below:http://hec-ras-bloggery-forum.1091112.n5.nabble.com/Inline-Structure-tp266p2
69.htmlTo unsubscribe from Inline Structure, click here
<http://hec-ras-bloggery-forum.1091112.n5.nabble.com/template/NamlServlet.jt
p?macro=unsubscribe_by_code&node=266&code=Z3JlZ2dAd2F0d2F5cy5jb218MjY2fC05Nj
g0NjQ4MzE=> .<http://hec-ras-bloggery-forum.1091112.n5.nabble.com/template/NamlServlet.jt
p?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.
namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.vi
ew.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemai
l.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aem
ail.naml> NAML——=_NextPart_000_0045_01CE9A98.15013430
Content-Type: text/html;
charset=”us-ascii”
Content-Transfer-Encoding: quoted-printableThanks for the response. I am seeing some pretty high velocities in =
the channel, so I would assume the effect would be negligible if there =
Greg K. Garrison
Staff Engineer
(831) 421-9291
ww=
w.watways.com =
[email protected]From:=
jarvus lunt [via HEC-RAS Bloggery Forum] =
Sent: Friday, =
To: Greg Garrison
Subject: =
Re: Inline StructureThe standard weir equation does not have =
an approach velocity, so no, I do not think RAS is taking it into =
account.
I’m not sure how much difference it would make. How =
high of velocities are you expecting? I don’t have any specific =
suggestions but you could adjust the weir coefficient value to try and =
account for the approach velocity.If you reply to this email, your message will be added to the =
discussion below:http://hec-ras-bloggery-forum.1091112.n5.nabble.com/I=
nline-Structure-tp266p269.htmlTo unsubscribe from Inline Structure, click here.
NAML =
——=_NextPart_000_0045_01CE9A98.15013430– -
