Welcome to the RAS Solution › Forums › HEC-RAS Help › Inlet Structure
- This topic has 3 replies, 473 voices, and was last updated 11 years, 1 month ago by Anonymous.
February 24, 2015 at 7:09 pm #5717AnonymousGuest
New Question. I have a stream channel that ends at a large yard inlet structure which runs to a manhole and then to a free outlet. My understanding is the inlet can’t be modeled in HEC-RAS and i need to create a ratings curve outside of hec-ras and then use the ratings curve in hec-ras. Is this about right?
February 24, 2015 at 8:40 pm #9149Chris G.KeymasterReturn-Path:
Received: from mail-pd0-f173.google.com (mail-pd0-f173.google.com [209.85.192.173])
by mbob.nabble.com (Postfix) with ESMTP id A9ED4924944
for; Tue, 24 Feb 2015 08:32:08 -0800 (PST)
Received: by pdjp10 with SMTP id p10so34555704pdj.3
for; Tue, 24 Feb 2015 08:40:18 -0800 (PST)
d=gmail.com; s=20120113;
bh=x1aSI9GPMZ8cN3W1Qoee4a7IK6k4GKUGhRuSLDh7q+8=;
b=U+86gcTinNhH/6CEKyswDWRDy14qj1uMJPNdPsZGhU2jMnF1GWEe9lbgijTpjjkZ7S
5armRW23VgPareg2BvU4ftvFHQdBa57LDD6cZGB/YhMHlHuAha9cy7lXtsCJO5m8b3Mk
gnKnPfY7xQHnjnn2Rop6Wan5IuIvxVe7AWagurTgfgb+I9wRxftmDN429v3x+IhBtODg
yZxYf/3E/1OgdDi1m47y+GHIsfnzQvSNUVLIeginTNzV1Mg9dqb+5uLouCO0xVtI7R7Z
MtCGAQ0VxsoIKPtG5Nxu04aalQitot/apIPJ1iO+0ko2qnB07Yl+fzUqIVKWHKbYIRgX
gXFA==
X-Received: by 10.66.235.1 with SMTP id ui1mr29775806pac.80.1424796018052;
Received: from ?IPv6:2600:1011:b11d:4f39:f9a7:9050:6fbd:18cb? ([2600:1011:b11d:4f39:f9a7:9050:6fbd:18cb])
by mx.google.com with ESMTPSA id y7sm2137360pdp.92.2015.02.24.08.40.16
for
Tue, 24 Feb 2015 08:40:17 -0800 (PST)
Subject: Re: Inlet Structure
boundary=Apple-Mail-7FBFF6E2-632B-4B1A-AD03-416FC9BE5390
X-Mailer: iPhone Mail (12A405)
Message-Id:
Date: Tue, 24 Feb 2015 09:40:14 -0700
To: “Andy [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-7FBFF6E2-632B-4B1A-AD03-416FC9BE5390
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableThat is correct.=20
Sent from my iPhone
> On Feb 24, 2015, at 8:09 AM, Andy [via HEC-RAS Help]
wrote:
>=20
> New Question. I have a stream channel that ends at a large yard inlet stru=
cture which runs to a manhole and then to a free outlet. My understanding is=
the inlet can’t be modeled in HEC-RAS and i need to create a ratings curve o=
utside of hec-ras and then use the ratings curve in hec-ras. Is this about r=
ight? =09
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Inlet-Structure-tp1356.html
> NAML–Apple-Mail-7FBFF6E2-632B-4B1A-AD03-416FC9BE5390
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitThat is correct.Sent from my iPhone
On Feb 24, 2015, at 8:09 AM, Andy [via HEC-RAS Help] <[email protected]> wrote:New Question. I have a stream channel that ends at a large yard inlet structure which runs to a manhole and then to a free outlet. My understanding is the inlet can’t be modeled in HEC-RAS and i need to create a ratings curve outside of hec-ras and then use the ratings curve in hec-ras. Is this about right?
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/Inlet-Structure-tp1356.html
NAML
–Apple-Mail-7FBFF6E2-632B-4B1A-AD03-416FC9BE5390–February 24, 2015 at 11:08 pm #9150AnonymousGuestThank you for the reply. Do you inpput the data as an “inline structure” or is there another place the ratings curve get sput in?
March 5, 2015 at 3:16 am #9151Chris G.KeymasterUse an inline structure and put in a gate. Then select “User-Defined” for you gate type.
