As stated before, I have a model with 2 different 2D Flow Areas that are connected via bridge.
I want to run the model with a certain initial water level in the upstream flow area, while the downstream flow area should start dry. The downstream flow area has some regions that are elevated below 0 masl. When I start the simulation, HEC-RAS automatically starts with an WSE of 0 masl in the downstream Flow Area instead of dry. Is it possible to change this?
