Hi Kendall. If your bridge abutments (as defined in the SA/2D editor) significantly blocks the bridge opening, then yes, you should include ineffective flow areas under the options menu item in the SA/2D editor. They will impact the bridge HTAB curves which are used to simulate the force impact of the bridge in 2D equations. And yes, it’s a good idea to use the 2D results to help inform how you would set up the ineffective flows (better that than to use the old “ratios” method.
