I have a problem with an increasing energy grade line in a model I have taken over. The geometry file have been used for steady state before and works well.
However, dynamic simulation is not working that well. The increase in EG appears over a converging junction. After the junction I have two reaches, A and B. In B there is a high weir and in A a lower, resulting in larger flow in A than B.
Where B starts, the EG line stays almost constant over the junction, but where A starts the energy grade line jumps up. The jump increases as I lower the weir.
The EG-line sinks marginally if I do increase Manning’s number in reach A.
I have already interpolated extra cross sections both upstream and downstream the junction with no effect. This junction uses the energy balance method. I also looked into Htab.
I’d like to get some suggestions for how to solve the problem.
Cheers,
Caroline
