Welcome to the RAS Solution › Forums › HEC-RAS Help › Importing results to Ras Mapper
  • #7194
    Juan Ossa
    Hello
    I received a HEC-RAS project that i have to check. I opened it and Ras Mapper works OK for all the plans i was sent. However, the other person the ran another model, and sent me the new results (plan, boundary conditions, etc.). The new model uses the same terrain, geometry and unsteady flows of other models i already have (i.e. i have all the data required to open the model), but even if i include the results in my main folder i cannot see the results in RAS Mapper? How can i check/open these new results in Ras Mapper? Is the only alternative to ask the other person to send the whole project again?
    I created some further results in Ras Mapper and would prefer not to use the new project, but to stick to the previous one and just import the new results. Any want has some hint to go through this?
    Regards
    #12025
    Chris G-M
    Hi Juan,
    One way to achieve what you’re asking is to manually include the Plan filename (*.pXX) into the RAS project file (*.prj) and then manually include the new plan results in the RAS Mapper file (.rasmap) using a text editor. Close and re-open HEC-RAS and RAS Mapper and the new results should populate.
    -Chris
    #12026
    Hi, I developed 2D model, it is quite big and could not run in one time so I run it in several (day by day). Finally I want to combine them together, it is possible or not?
