Welcome to the RAS Solution Forums HEC-RAS Help Importing only the bridge data
  • This topic has 4 replies, 383 voices, and was last updated 7 years ago by Manny.
  • #6871
    Manny
    I am running multiple RAS models with different geometric data imported using HEC-geoRAS into RAS from Different DEMs which I created. Though the cross section data is different for each run the underlying bridge/culvert data is the same. Is there a way to only store the bridge/culvert data and include that every time run the model? Manually copying them is a long painful processes.
    #11338
    The bridge data can be imported from one HEC-RAS geometry file to another. Go to “Import Geometry Data” under the file drop down menu in the geometry data editor in which you want to add the bridge. When importing data from other HEC-RAS geometry files, specific cross sections and/or structures can be selected for import. Select the bridge data you want to import and unselect the remaining data.
    #11339
    Manny
    Thank you for the solution Keith M. Though i just selected the bridge data to import, there are addition cross sections with no data being created. Is there a cleaner way to get rid of them than deleting them individually?
    #11340
    Hi Manny. The extra cross sections being added must be frustrating. I don’t know a way of removing them other than to delete them manually.
    #11341
    Manny
    Return-Path:
    by sloti1d2t14 (Cyrus 3.1.3-348-ge94e049-fastmail) with LMTPA;
    Fri, 04 May 2018 08:58:54 -0400
    X-Cyrus-Session-Id: sloti1d2t14-2063599-1525438734-2-11753235503308337673
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 0.0
    X-Spam-hits: BAYES_00 -1.9, FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001,
    RCVD_IN_DNSWL_NONE -0.0001, RCVD_IN_MSPIKE_H2 -0.001, SPF_PASS -0.001,
    URI_HEX 1.122, LANGUAGES en, BAYES_USED global, SA_VERSION 3.4.0
    X-Spam-source: IP=’209.85.223.174′, Host=’mail-io0-f174.google.com’, Country=’US’,
    Received: from mx2 ([10.202.2.201])
    by compute1.internal (LMTPProxy); Fri, 04 May 2018 08:58:54 -0400
    Received: from mx2.messagingengine.com (localhost [127.0.0.1])
    by mailmx.nyi.internal (Postfix) with ESMTP id 3DF94D834C
    for ; Fri, 4 May 2018 08:58:54 -0400 (EDT)
    by mx2.messagingengine.com (Authentication Milter) with ESMTP
    id F58E1C2552F;
    1525438734; b=NOZIxLjnfu8S7tIs9w2faTDfxdQCAcpJs8KKp0sZL3wTVwLKdO
    3AV5HTji/M9AghvjixcNAUZaMyE3K4bWy3XlAS/v9oWPxAGs6KYiiSfYnkEsHUCT
    mUaoroEyrEl0UWJSS+QzzrbKwz8dUl2Ff4ZniDNYNdDLiLeP0qMsvyFPaEg1J5wS
    CcIzPr55ryi81wZfQ9JslgjQ51aS0corUvftJ/hnl0xmlhhOCaiVJZ7e7A+wpt3g
    odmBBlJmMvpyWfw5dKV7zusJr+gM6pvUT+gn6nPQJaaQ+ZerNaAGtGCKvtG5pXpQ
    FjwP4BBlMDRMkkR15qnwPOH02rWFzC3g4zoQ==
    messagingengine.com; h=mime-version:in-reply-to:references:from
    :date:message-id:subject:to:content-type; s=fm2; t=1525438734;
    bh=6k2DIqBsiIAZ0+H7lSD/T4i70VDqKNPjNVDkhYCzZts=; b=P/P39rOSEsnj
    xfYxVaBWgDXHSLHyXukhDmClkcIkevAR445WLwOTAETEpKx9iCEe7OxTj3uA6NdI
    DG8jqgQQjIFJbOqrlVQuj0rRYwieFufBT67pupV8lMklUaDbB7jQZA7FlBIBakVq
    u922MjAiAbmz+JR3oIMDHPOKBYjtuTjziD7XM3VTWIuHZK3GlDbH0i8BMf/wuxf/
    TR4Cuer8DN8TCr3Pj/Ma6xGGPms+mTiHJt1QHjjyqsX9oT/HxyuTOA735SY+wZR4
    qszMULtcdSA3mPys4cUezk9GErAYr+v1O4ptzdmOlGm6dO/+i0sPkE2qHapWITWO
    liCTf4QFUw==
    ARC-Authentication-Results: i=1; mx2.messagingengine.com; arc=none (no signatures found);
    [email protected] header.b=OATaq0Hv x-bits=2048 x-keytype=rsa
    x-algorithm=sha256 x-selector=20161025;
    dmarc=pass (p=none,d=none) header.from=gmail.com;
    iprev=pass policy.iprev=209.85.223.174 (mail-io0-f174.google.com);
    spf=pass [email protected]
    smtp.helo=mail-io0-f174.google.com;
    x-cm=none score=0;
    [email protected] header.b=H9jwg90k;
    x-ptr=pass x-ptr-helo=mail-io0-f174.google.com
    x-ptr-lookup=mail-io0-f174.google.com;
    x-return-mx=pass smtp.domain=gmail.com smtp.result=pass
    smtp_is_org_domain=yes header.domain=gmail.com header.result=pass
    header_is_org_domain=yes;
    x-tls=pass version=TLSv1.2 cipher=ECDHE-RSA-AES128-GCM-SHA256
    bits=128/128;
    x-vs=clean score=0 state=0
    Authentication-Results: mx2.messagingengine.com;
    x-cm=none score=0;
    bits=128/128;
    X-ME-VSCategory: clean
    X-CM-Envelope: MS4wfKyPWZK0wCvgCRtduxnEJIZGBNZt9O505+ySBkJd1gxXMxGHxiHDjyAbYu4wXzuaWfaHHuiLJYrIRfC3Ex3CdqMYM+pNkR0ZyY3XzMCMq3sdXPOUufxE
    Le7DzN9E/mLx1FQTrJSkCNruG4es4Xln1YJ394VNDQqmt+SbH9eo4Gd0YrpV+IWPSe7xWDyG6ciBpjEMBcVD7W+tvm+/ohSzu6t601j3clPHLoKCDXhvaXWV
    X-CM-Analysis: v=2.3 cv=E8HjW5Vl c=1 sm=1 tr=0 a=MAC9HxUk7fez6cFlCIg1Bw==:117
    a=x7bEGLp0ZPQA:10 a=OPttG4M7PuoA:10 a=VUJBJC2UJ8kA:10 a=9I5xiGouAAAA:8
    a=xLHUm1dHh4UfRAJiAdkA:9 a=QEXdDO2ut3YA:10 a=vV2ycgvOAmNHkcHhv8YA:9
    a=IHHoDwvBaSY0U0C8:21 a=jOGS7EXTvewA:10 a=ARFN2YZ7Uv8kHtb7LS-q:22
    X-ME-CMScore: 0
    X-ME-CMCategory: none
    Received-SPF: pass
    (gmail.com … _spf.google.com: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:_netblocks.google.com’ matched))
    receiver=mx2.messagingengine.com;
    identity=mailfrom;
    client-ip=209.85.223.174
    Received: from mail-io0-f174.google.com (mail-io0-f174.google.com [209.85.223.174])
    by mx2.messagingengine.com (Postfix) with ESMTPS
    for ; Fri, 4 May 2018 08:58:53 -0400 (EDT)
    Received: by mail-io0-f174.google.com with SMTP id g14-v6so21825233ioc.7
    for ; Fri, 04 May 2018 05:58:53 -0700 (PDT)
    d=gmail.com; s=20161025;
    h=mime-version:in-reply-to:references:from:date:message-id:subject:to;
    b=OATaq0Hv1YPGWj03P1BJwIKoJCaAi3KYsmo7B5iub/qhH6ynAfhyoJIosE93zIadNF
    /M6U/N16+etGFGZPJoefKQw+8JPyKf7c1pkNNDywvbWruhacoYv/ePMAsjzfZTW4IqET
    23mVs8lYOJAL7nR80EGS+q3g5qqS59ZsfeQiuzIZuuM8CY7dYSkClE3Dm7yFePcSs+Kd
    p2Tk6uJnT3TOow1xD7PfnjGDJHrHMVKeiobQVCHBkP8vRorQHGtu3AS6ZyT6AhTEAmkv
    QD0RG79sVKcp6BoD19ik19CC8RVpNo9IPM3oO4OUi19Z8N22HOzoSOzsf8aZTIYO07nR
    EWFg==
    d=1e100.net; s=20161025;
    h=x-gm-message-state:mime-version:in-reply-to:references:from:date
    b=H9jwg90kQklvEhRbnP2d/M3g05WiBwIcywX0PYlYR+OvwAN+qWCXOgdjynPe7/q+gt
    rPyQr0sxEJZAcOYibUMekxxP2+/0eRyxX2uV4KT7cb/flAQqUtnN6QhXMUOc9wyqnxeM
    VZEiMAe7axKyUgGtmX8NIfT5HcOk79gLyqRP+CBCQ2EIiyBIyz5OCricwjF5pr2Y/jPB
    f/9SGw+dP/g7PQFoaQWmhgCGtBQ9sC+1UN9gjpz2BoYfUneZVi+TDtKN9HN6Qt9l8QSi
    32mJEsLG4IjgA+fdUbwZxR/fm/fWMrycIwnKJ08HzmWHdmFFvoVjZs6m9fSdn/QiuRsL
    gzHA==
    X-Gm-Message-State: ALQs6tAm/UhFYslMIy6rBEN8oin67TBGA7pjrUDdVoubtzuEwKhOU/2h
    3h6kTi7l0YUarHBfdvF5WQXffho6Zk3Klu6q37U=
    X-Google-Smtp-Source: AB8JxZpO2cI6GrTIwuqeAtlJmAsYgCdYKG5bMaMOBb0N+OtsVCSMoRQLEjqXb/K83qpLxbePU3l4SgC/OKChvqwIBQQ=
    X-Received: by 2002:a6b:a242:: with SMTP id l63-v6mr29559990ioe.179.1525438732099;
    Fri, 04 May 2018 05:58:52 -0700 (PDT)
    MIME-Version: 1.0
    Received: by 10.107.130.39 with HTTP; Fri, 4 May 2018 05:58:51 -0700 (PDT)
    Date: Fri, 4 May 2018 08:58:51 -0400
    Message-ID:
    Subject: Re: Importing only the bridge data
    To: “Keith M [via HEC-RAS Help]”
    Content-Type: multipart/alternative; boundary=”000000000000c0f1d7056b60e1c6″
    –000000000000c0f1d7056b60e1c6
    Ok, I will manually delete them. Thank you again for your help, I
    highly appreciate it.
    On Fri, May 4, 2018 at 8:54 AM, Keith M [via HEC-RAS Help] < [email protected]> wrote:
    > below:
    > http://hec-ras-help.1091112.n5.nabble.com/Importing-only-
    > the-bridge-data-tp5518p5533.html
    > To unsubscribe from Importing only the bridge data, click here
    =3Dunsubscribe_by_code&node=3D5518&code=3DbWFub2hhcnNlZXRoYXJhbXVAZ21haWwuY=
    29tfDU1MTh8MTQ5NDcwMjI5NA=3D=3D>
    > NAML
    ace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers=
    %21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_em=
    ail%21nabble%3Aemail.naml>
    Ok, I will manually delete them. Thank you again for your =
    help, I highly=C2=A0appreciate=C2=A0it.
    On Fri, May 4, 2018 at 8:54 AM, Keith M [via HE=
    C-RAS Help] <[email protected]> wrote:
    border-left:1px #ccc solid;padding-left:1ex">
    Hi Manny. The extra cross sections being added must be frustrating. I don&=
    #39;t know a way of removing them other than to delete them manually. =C2=
    =A0
    =09
    =09
    =09
    http://hec-ras-help.1=
    091112.n5.nabble.com/Importing-only-the-bridge-data-tp5518p5533.<= wbr>html
    =09
    To unsubscribe from Importing only the bridge data, click here.
    NAML
    –000000000000c0f1d7056b60e1c6–
