Welcome to the RAS Solution › Forums › HEC-RAS Help › Importing data for calibration of model
- This topic has 3 replies, 742 voices, and was last updated 11 years, 6 months ago by samiul.
September 27, 2014 at 2:22 pm #5599samiulParticipant
For calibration of a model ,we have to plot obseved data vs model simulated data in an excel worshit for a fixed time range.I am very much curious that if any option exist in HEC-RAS to give the obsedved or field data as input and make direct comparison,so that we don’t have to do this in an excel worksheet.If any,please share the process.It’s to be a great help.Thanks.
September 28, 2014 at 6:14 am #8961cameronParticipantIn the Flow Editor|Options pull down menu there is an option to add observed data as either high water marks, gage rating curves, or hydrograph. You then can turn on observation marks in the profile plot as a variable.
September 30, 2014 at 11:06 am #8962samiulParticipantReturn-path:
Envelope-to: [email protected]
Delivery-date: Mon, 29 Sep 2014 23:06:35 -0700
Received: from mail-qg0-f47.google.com ([209.85.192.47])
by sam.nabble.com with esmtp (Exim 4.72)
(envelope-from)
id 1XYqa3-0002J0-6k
for [email protected]; Mon, 29 Sep 2014 23:06:35 -0700
Received: by mail-qg0-f47.google.com with SMTP id i50so2862340qgf.20
for; Mon, 29 Sep 2014 23:06:29 -0700 (PDT)
d=gmail.com; s=20120113;
h=mime-version:in-reply-to:references:date:message-id:subject:from:to
:content-type;
bh=98/PsUuaSBcPf+D8Co2FBQxmJG0VuZkeTcB11EYd82M=;
b=mmKnjbZULC+ItQblCgHVMF11PORwqUVuUzQawJ03F2LdzGWFDuq6gYVVW0xmFTBSIM
tBhXRcdxdfT/ptvB/hds/7EC9gDGMflemK0+t5n7Tu5N8pV/217cGQADm9cuq5vPMvJK
c1OQHPjgG9CvcPW1BbvemTnR0pjUNBNtQ4dZgLOhuBwqJp3RI0QIkvjo1QV/K2Fh0yaa
EavyjIsic4+jOnEkNtGSVkfyKtf3m0dCcxWfoMSvatWulnWmHR4R5qAcUsu9hYgRSeha
rOffwmIIrBg9wmxe25OdO73pvhfq5GGyaChghh0DcNuOpGcpZjN1E8ft0qN3cS06npCa
/DkQ==
MIME-Version: 1.0
X-Received: by 10.140.86.145 with SMTP id p17mr66489738qgd.57.1412057189870;
Received: by 10.140.84.213 with HTTP; Mon, 29 Sep 2014 23:06:29 -0700 (PDT)
<[email protected]>
Date: Tue, 30 Sep 2014 12:06:29 +0600
Message-ID:
Subject: Re: Importing data for calibration of model
Content-Type: multipart/alternative; boundary=001a11c124983470b00504422ffa
X-SA-Exim-Connect-IP: 209.85.192.47
X-SA-Exim-Mail-From: [email protected]
X-SA-Exim-Scanned: No (on sam.nabble.com); SAEximRunCond expanded to false–001a11c124983470b00504422ffa
Content-Transfer-Encoding: quoted-printableDear Cameron,
Thanks for your suggestion.but i have a question.What will be the format of
the obseved data value?is it possible to make a xcel data sheet make
compatible witjh hec ras data input system.Sincerely yours,
SamiulOn Sun, Sep 28, 2014 at 7:14 AM, cameron [via HEC-RAS Help] < [email protected]> wrote:
> hydrograph. You then can turn on observation marks in the profile plot a=
s
> a variable.
> below:
> http://hec-ras-help.1091112.n5.nabble.com/Importing-data-for-calibration-=
of-model-tp1006p1007.html
> To unsubscribe from Importing data for calibration of model, click here
=3Dunsubscribe_by_code&node=3D1006&code=3Dc2FtaXVsMTY5QGdtYWlsLmNvbXwxMDA2f=
C0xMzA0MTU3MTky>
> NAML
ace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers=
%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_em=
ail%21nabble%3Aemail.naml>
Content-Transfer-Encoding: quoted-printableDear Cameron,Thanks for your suggestion.but i have a =
question.What will be the format of the obseved data value?is it possible t=
o make a xcel data sheet make compatible witjh hec ras data input system.= div>Sincerely yours,SamiulOn Sun, Sep 28, 2014 at=
7:14 AM, cameron [via HEC-RAS Help] <ml-node+s109111=
[email protected]> wrote:_quote" style=3D"margin:0 0 0 .8ex;border-left:1px #ccc solid;padding-left:= 1ex">
In the Flow Editor|Options pull down menu there is an option to add observ=
ed data as either high water marks, gage rating curves, or hydrograph.=C2=
=A0 You then can turn on observation marks in the profile plot as a variabl=
e.=09
=09
=09
will be added to the discussion below:–001a11c124983470b00504422ffa–
October 1, 2014 at 12:52 am #8963RobertParticipantHi,
I am devoting dam break model.
I want to ask the calibration options in unstedy flow [dam break routing]?I think, that a Rating Curve we can’t use, because it is very complicated or impossible to calculate for cross section, where is a built-up area, … .
We can’t use also High Water Mark, because dam break is potential case, we have any historical records.thank you very much
Greetings! -
