Welcome to the RAS Solution Forums HEC-RAS Help Import n value breaks into GIS
  • #6456
    When exporting GIS data from HEC-RAS, I select all the additional properties to export. When I go into GeoRAS and set up and run the RASMapping feature, data is imported — I get my Bank Station points and Water Surface Extent Points, but I do not get the n value break points.
    I went into the ArcGIS Catalog and looked at the geodatabase, and n values are NOT there.
    I opened the xml file of the HEC-RAS output, and the n values are there!
    So, my question is, is there an easy way to get this information from the xml file into ArcGIS? I need to create a map showing these roughness values post channel modification.
    Julia
    #10569
    no reply?
    This is a very important question.
