Welcome to the RAS Solution Forums HEC-RAS Help Hydraulic tunnel model
  • #17985
    GMF
    Hello, good morning;
    I have modelled a long hydraulic tunnel (circular section) adding Lids in each cross section of the tunnel.
    I have defined the bottom half of the section with Cross Section Coordinates (Station/Elevation) and the top half adding Lid with High and low coordinates (Station/High elev/Low elev).
    the model apparently works properly but I have some doubts:
    1- Which are the Manning´s Values at the lid (top half of the section) and how could I edit them?
    I have slight deviations results between the model and simple check calculation in uniform regime and it could be because of that.
    2 – When I check the result table of the model, I notice the top width is slightly bigger that the diameter (4.5m versus 3.7m approximately) What is the reason?
    Thank you very much for you Help.
    Kinds Regards
    GMF
    #18283
    Romain PAUL
    Do you find an answer for your Manning into the LID? I have the same doubt.
    Thank
    #18285
    Luis Partida
    Mannings values are still controlled by the cross-section data editor just as if a Lid is not in place. If you want to vary roughness within the tunnel use vertical variations in mannings values by clicking options
