Welcome to the RAS Solution Forums HEC-RAS Help Hydraulic performance of multibarrel culvert under inlet control
  • #5929
    Calvin Leung
    I am conducting the hydraulic performance analysis for both multibarrel and single-barrel culvert systems under inlet control. In current practice, single-barrel culvert design procedures have been applied to multibarrel culverts by treating each of the barrels in the multibarrel culvert as a single culvert and summing the individual flow capacities(superposition). However in the real situation, multibarrel culvert does not have the same hydraulic performance as a single-barrel culvert because the amount of inlet flow contraction associated with each culvert in a multibarrel culvert is less than the flow contractions experienced by a single-barrel culvert. Therefore, the method of superposition does not apply to multibarrel culvert. I want to know if HEC-RAS utilizes the method of superposition or have the ability of modelling the real situation considering the effect of contraction when analyzing a multibarrel culvert.
    Thank you so much!!!
    #9566
    user
    One way I can think of is adjusting the ineffective flow area before and after the multiple culverts.
    #9567
    So HEC-RAS evaluates the flow capacities of a multibarrel culvert by treating each of the barrels as a single culvert and summing up their flow capacities?
    #9568
    user
    Yes. If you want the individual flow for culverts of different sizes , just specify more culvert groups . At the end , you would get the summation of their flows.
