• This topic has 2 replies, 293 voices, and was last updated 9 years ago by Anonymous.
  • #6333
    Hy!
    I have one question about data written in hydraflow. I created hydraflow, witch has informations about flow for 24 hours. At begining my hydraflow contains data where flow is 0 and then rise to 160 m3/s and then dops to 0 again. This same hydraflow is my boundary condition for 2D model and combine 1D/2D model. 2D simualtion works perfectly, but in combine model those data with flow=0, brings some errors. So simulation went trought, but at beggining and at the end, where my flow is 0, results show that I have some water in my channel and also on my flood areas. Later I changed data that contains 0 m3/s flow to 1m3/s. Simulation went trought perfecty and is stabile. So can anyone tell me why program doesn’t like flows values if they are set as 0?
    THANK You!
    #10352
    1D models require to have flow in the channel no matter what or the model will go unstable. 2D models do not require this.
    #10353
    Thank You!
